SRS light is on
Old Aug 28, 2004
webtekie's Avatar
webtekie is an unknown quantity at this point
SRS light is on
I have 2001 Honda Civic EX. All of the sudden my SRS light came on. Is there a way I can turn it off? I went to the shop and they checked air bags and everything check out ok. They just don't know how to turn the light off.
thanks,
webtekie
Old Aug 29, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Yes there is DIY...
Or you can do like me and just put the steering wheel low enough so you never ever see it, but my airbags are all messed up so I cannot really reset.
Old Aug 29, 2004
webtekie's Avatar
I found this. Has anybody else tried it? Does it work? Is there a possible damage to electric system?
Old Aug 29, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Yup it works , its difficult tho and may take you a few tries.
Old Aug 30, 2004
Da1lyDr1ver's Avatar
just use a small paper clip to stick into the plug, it works the same so you wont have to buy a special connector. it worked for me.
Old Sep 24, 2004
bakuretsu's Avatar
bakuretsu is an unknown quantity at this point
This certainly works. The linked article suggests using a piece of speaker wire, hooking one end into the plug and shorting the leads at the other end. This, in my opinion, is brilliant. No bending over and contorting yourself to stick a paper clip into the plug.
I got it on the first try, gentlemen.
Old Sep 24, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
what i did was jam in 2 wires into the plug and the wires attached to a switch.. turn the switch on and off as per the diy
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
XtremelySpoiled
Dec 13, 2001 08:47 PM
SimDogg
Nov 27, 2001 04:20 PM
