CEL after flywheel install
Old Sep 19, 2004
Ichiban's Avatar
Ichiban is an unknown quantity at this point
I installed a new ACT prolite flywheel (8.4 lbs) about 4 days ago and the CEL came on yesterday. I remember there was a thread about it a while ago but I searched and couldn't find it. So my first question is do the 7thgens have a knock sensor, if it does then that might be the problem due to more vibrations from the lighter flywheel. That is my theory. I really don't know what else it could be. If someone had the same problem how did you fix it if you did. Thanks
Old Sep 20, 2004
vipergtsr's Avatar
vipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trustedvipergtsr should not be trusted
I chose to go with the 11.3 lb flywheel instead of the 8 lb. I have not had this problem. Did you install the flywheel or did you have it prof. installed? If so I would check with them to see if they can check the code for the CEL.
Old Sep 20, 2004
Ichiban's Avatar
Me and my friend did it. But the light went off today when I was driving.
jzhartman
22
Jul 23, 2015 10:42 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
CivicsClass101
Jul 9, 2015 11:14 AM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
