Crap... Rain Got In My Car
Old Oct 7, 2004
LowRYda03ex's Avatar
LowRYda03ex is an unknown quantity at this point
I left my windows open in my car the other day thinkin that i would be right back out, but it turns out i fell asleep on the couch. It was my luck that a huge rainstorm happened to come by that very day, drenching the inside of my car, and now I lost my new car smell! and now it smells a little bit muggy inside. Is there any good way to fix this besides something stupid like an air freshener?
Old Oct 7, 2004
VietScouty's Avatar
VietScouty is an unknown quantity at this point
Sorry no can do...I remember when I left my sunroof open in my integra...and it gotten soaked but no muggy smell...
Old Oct 7, 2004
nikoscivicex's Avatar
www.8thgencivics.com
nikoscivicex is an unknown quantity at this point
Always roll your windows uP?...
Old Oct 7, 2004
like i said before, i thought i would be right back out but i fell asleep.... and now im left with that crappy smell. I think i might just get the interior fully detailed and cleaned and hopefully it will fix the problem
Old Oct 7, 2004
lkm's Avatar
lkm
Super Member
lkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trustedlkm should not be trusted
sell car. buy nuther one
Old Oct 7, 2004
you guys arent helping
Old Oct 7, 2004
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
Ive done this before, if its not like soaking wet and its just damp, all you have to do is run the car for a long time in your driveway with all the windows up, the heat on full blast with the A/C on. The heater will help dry while the AC takes the moisture out of the air. This has worked for me on numerous times. After that, if its a nice day, park it in the sun with all the windows open, assuming you can do this or trust that it wont get broken into. If its really wet, take a dry-vac to it first to get as much water out as possible and then do the above steps. Should work, it worked for me on a lot of occasions and i got the smell out without having to remove the carpeting or any of that junk.
Old Oct 7, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
advance auto parts sells these small boxes about 8"x8"x3" with some stuff inside that absorbs moisture, only $5. worth a shot.
Old Oct 7, 2004
smooth14's Avatar
smooth14 is an unknown quantity at this point
DIY for getting mildew smell out of rained in car
I worked in a detail shop for a while so i may be of some help what we usually done was
1)removed the carpet and let it dry
2)after you remove the carpet if you look at the fire wall you will see some black rubber it has foam on the back side of it check to see if the foam is wet if it is prop it up and let it dry out before replacing the carpet after you dry it out spray bleach on the foam to kill any bacteria that is growing in there also you may wnt to spray down the floor board w/ bleach make sure you remove the back seat completely or you will wind up w/ little white bleach specks on it
3)next turn the carpet over and peal off all of the padding on the back side of the carpet and trash it once this gets wet you will never get the smell to leave the car
4) now that you are down to the black lining of the carpet scrub this down with some tilex tilex will kill any mildew and it wont discolor the carpeting if it bleeds through
5)if you have access to a carpet shampooer shampoo the carpet really good if not you can probably take the carpet to your local detail shop and they will shampoo the carpet for you for less than $35
6)go to your local carpet company and purchase some home carpet padding and cut it to match the old padding
7) using some spray adhesive (3-m general trim adhesive works the best can be purchased at advanced auto or autozone) glue the padding to the back side of the carpet where the old padding was
8)make sure the the carpet and everything on the inside of the car (including foam on the backside of the rubber on the fire wall) is completely dry and reinstall the carpet
Old Oct 7, 2004
ctx66's Avatar
sounds easy enough! just take the carpet out!
Old Oct 7, 2004
smooth14's Avatar
it does require some time and patients but sometimes it's the only thing that works
Old Oct 7, 2004
Ledbelly's Avatar
Im the man in the box
rain gets in my car all the time ... just check the weather and leave your windows down for an afternoon or two it will air out
mikemc422
Aug 9, 2018 05:41 PM
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
WhosYoDadday85
Bolt-on Engine Performance
Nov 6, 2001 08:06 AM
ZSKCivic01
Nov 4, 2001 08:47 PM
