Tie Rod End Spinning
Old Sep 12, 2004
Dragncrosmember's Avatar
Dragncrosmember is an unknown quantity at this point
Any I deas on how to keep the stud from spinning so I can tighten up the nut? I'm hopping that I don't have to replace it.
Old Sep 12, 2004
abmerop18's Avatar
Jam out with your clam out.
put pressure on top of it with the OEM jack. open up the jack so it gets as big as it can and that should put enough pressure on there to let you tighten the bolt.
i had this same problem when i was doing my springs, but i later found out i overread this part of the install in the DIY.
good luck man
Old Sep 12, 2004
That did the trick! I must have read past that part too. I wish I had $135 though.
Sep 26, 2023 06:44 PM
alwaysloyal360
Jul 29, 2015 02:26 PM
Dangerousjordan
Jul 28, 2015 08:24 AM
17
Jul 23, 2015 11:48 PM
cyc
Jul 22, 2015 01:14 PM
