Should I do my own ball joints/ tire rod ends?
Old Jul 25, 2015
Dangerousjordan's Avatar
Dangerousjordan is an unknown quantity at this point
2002 Civic. I got a quote for $180 with alignment for driver lower ball joint and passenger out tie rod. The alignment is $60 on it's own. I have experience doing engine DIY projects but haven't touched suspension. Will I need more parts than in your basic toolkit? Thanks guys. I realize this is subjective, just wanting to weigh the pros and cons...
Old Jul 25, 2015
emich's Avatar
emich is an unknown quantity at this point
Re: Should I do my own ball joints/ tire rod ends?
rent the tools you need and is easy.
Old Jul 25, 2015
GolNat's Avatar
Prelude Owner
Your going to need some bigger tools (1/2" drive) and you can rent the ball joint seperator and fork for tie rod end.
How much is your time worth? $180 does not sound to bad. Is $180 worth it if it takes you 4 hours of your time?
Old Jul 25, 2015
Hell yeah man I'm making $10/hr right now lol thanks for the input guys
Old Jul 25, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Harbor freight or northern tool has the ball joint separator cheap, but many autoparts stores will loan you the tools with a refundable deposit. You can get parts from amazon or rockauto for 30-40% less than the parts stores. Usually the same parts.
Old Jul 26, 2015
mikey1's Avatar
ball joints can be very dangerous if not installed properly,
i would suggest reading this entire thread.....
https://www.civicforums.com/forums/3...ml#post4687729
make sure you fully understand and follow the service bulletin i have attached in one of my replies there, good luck
Old Jul 26, 2015
remember the ball joints are pressed in, so a PITA to remove.
aftermarket one will likely have a ring holding it in place instead.
Old Jul 26, 2015
OptimisticWay's Avatar
OptimisticWay is an unknown quantity at this point
This is the best tool for the job when you need to reuse your balljoints:
http://www.harborfreight.com/3-4-qua...tor-99849.html
20% off coupon here:
http://www.dealsoff.com/harbor-freight-coupons/
You need to go cheap so, rent the balljoint and the other fork tool for tierods from your local auto parts store for free minus gas for traveling. You will also need the press and Honda adapter kit for ball joints. You would then need a circlip tool and Craftsman is the best and cheapest at $25... You know what just pay the $180. If you have the time, want the experience, and you are willing to buy the tools, you will likely break even when you add everything up INCLUDING gas to and from every store.
Old Jul 26, 2015
Unless it is rusted in, these balljoints fall out even when you don't want them to on 7th gens. A floor jack from underneath works great.
Old Jul 28, 2015
SammySC's Avatar
SammySC has a spectacular aura aboutSammySC has a spectacular aura about
$180 is a good price, go for it. I just got a $948 quote from the dealer to replace passenger side ball joint!! Of course this is Ny and everything is more expensive!!
bravo79
Suspension
18
Feb 10, 2022 09:52 PM
hans.pcguy
Jul 12, 2015 12:19 PM
mrohitredd
May 28, 2015 10:03 AM
pheaton
May 4, 2015 08:26 PM
El_Spic
Apr 23, 2015 03:14 PM
