2000 honda civic steering clunk
Old May 7, 2015
bravo79's Avatar
bravo79 is an unknown quantity at this point
Hi everyone. I'am trying to get this issue resolved but it seems to be little confusing to me. I have a 2000 honda civic DX with power steering. I started to hear a clunk nose when going over bumps or when shaking left and right the steering wheel. I have changed out the inner and outer tire rods. So far its still doing the same thing. I belive the clunking is from the rack it self as I can see the inner tie rod moving. If you watch this video you will have an idea what I am talking about.
EZone are you there? You helped me allot last time with the steering hub situation on my 01 civic
Thank you!
Old May 7, 2015
Stock 99's Avatar
Re: 2000 honda civic steering clunk
The clunking going over bumps could be your upper control arm bushings but not related to the play in the steering your displaying in that video. Check your lower ball joints?
Old May 7, 2015
bravo79's Avatar
I can see/feel its loose though. If I look at the inner tie rod from the driver side I see the movement almost like the rack is causing it. I know there is an adjustment guide that needs to be adjusted but not sure if this is related to clunking noise
Thank you for the response!
Old May 12, 2015
bravo79's Avatar
Any one?
Old May 14, 2015
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
Had the exact same problem with my 2005 Civic. Not too knowledgeable with the 6th gens, but could be the stabilizer bar connections.
#4, #13 and #20. I changed mine and the clunking is gone!
http://torontohondaparts.com/Honda/C...LOWER_ARM/6600
Old May 14, 2015
Stock 99's Avatar
DX trims didn't come with stabilizer bars
Old May 15, 2015
Reverb2005's Avatar
Ahhh, well that makes sense why Majestic Honda doesn't actually list the part and price even though it shows up on the parts diagram.
Old May 20, 2015
bravo79's Avatar
I might end up replacing the rack but I dont know if there are bad ones and good ones out there. I am not sure if this is relate however
http://honda-tech.com/honda-civic-de...blems-3095792/
Old May 21, 2015
Reverb2005's Avatar
How's your power steering fluid level?
When you are driving the car, does the power steering actually work? Does it work well, like it is supposed to? (Minus the play in the wheel)
Confirm where the noise is coming from first. Get someone to move the wheel and get in behind the intake manifold and feel if the clunking is coming from the rack itself.
Old May 21, 2015
bravo79's Avatar
Power steering work well. No leaks at all. No noise. The only thing is the clunk when moving the steering right and left. Also clunk when going over bumps. I think there is a looseness somewhere. I ordered the rack from autozone. I think its dura last brand refurbished or whatever. I will try to do my best identifying the source before opening every thing because it's pain to do so. Thanks for the reply
Old May 22, 2015
bravo79's Avatar
Here is a video of the issue I just took
Old May 23, 2015
bravo79's Avatar
And here is another one. i did adjust the rack guide screw and it didnt help a bit!
Old May 24, 2015
bravo79's Avatar
So last night I tried opening it and ended up stripping the power steering hard line. I was using a flare wrench though
I put it back together and I'm going to take it to a shop to get it replaced. I was getting vertigo as well looking up at the thing laying down underneath the car.
I noticed that the rack is dry ! No grease at all. Also when I opened the rack guide it was rusted. Not sure now if greasing the r ask might stop the clunking
Hope some on here can help!
Old May 25, 2015
Reverb2005's Avatar
You mean the fitting that attaches the main power steering fluid line?
Besides that, let's get our bearings on the issue....
Ok, so, tie-rods connected to either end of the rack. When you move the wheel back and fourth, does all this move as well? I know you cannot see the actual internal rack with the boots on, but do the tie rods move loosely with the steering?
OR, do the rods stay put and you see no external movement in the loose area of the steering?
Did you determine whether the knock is coming from inside the rack?
You say you have "no leaks", but I just want to confirm, IS the power steering fluid full in the reservoir? Power steering fluid can leak into the dust boots and remain there, hidden from view.
Did you push the boots back when you did the tie-rods?
Old May 26, 2015
bravo79's Avatar
I think it's the hard retun power steering line. The clunkingmovement is coming from inside the rack. Looks like the old bellows were damaged and water got inside
the rack is dry and rusty from inside. I grabbed one end of the rack while the inner tie rod disconnected with a vice grip and I can replicate the clunking. pusing inward and moving clock and counter clock produced the clunking.
The vertigo I get when working under the car is making it hard for me to do anything at this point. This is the first time I'm letting someone work on one of my cars.
Old Jul 31, 2019
ysnantt's Avatar
ysnantt is an unknown quantity at this point
Hey man, I have the same type of play in my car. I replaced almost every front suspension part except lower control arms and the rack and pinion itself. after installing all my parts and getting an alignment, week later my steering wheel started pulling left and I got the same clunking noise as you do in the videos. my question is did you end up replacing the rack and pinion and did it make that annoying clunking noise go away???
Old Jul 31, 2019
Maburke03's Avatar
Maburke03 is an unknown quantity at this point
Sounds like an intermediate shaft. Also check your motor mounts. If there are chunks missing from the rubber area it could cause movement
Old Aug 2, 2019
Maburke03's Avatar
Oh wow. Come to find out that that the pulley was installed backwards! This led the timing belt to slip ( which is the reason I started the job). AND the tensioner spring was incorrectly installed which may have contributed to slack in the belt. Originally I had a crank no start issue. At the start of this my timing mark on the crank was out off the mark by quite a bit. So now I have a new water pump timing belt idler pulley and ac belt.
Old Feb 10, 2022
mkamal's Avatar
mkamal is an unknown quantity at this point
Did you ever find a solution? Same issue. Changed the motor mount, all tie rods, sway bar link & bushings, full shock assemblies, the issue remains. Just to confirm it makes the noise when turning left right while parked and also on uneven pavement. If it helps the passenger side tie rods where worn a bit but not that much. Sound is definitely center/passenger. Thanks
brassfit
Suspension
15
May 23, 2021 11:34 PM
c3rberu5
Jul 27, 2016 01:18 PM
JJ291
7th Gen Do It Yourself Articles
May 10, 2016 07:46 AM
rsrchgy
North East
Mar 28, 2014 01:07 PM
silver04si
Apr 28, 2008 07:47 PM
