Low Idles, then stall
Old Sep 30, 2004
reddsunns's Avatar
reddsunns is an unknown quantity at this point
HI, I have a 97 Honda Civic LX. I just hit the 113000. Recently the car have been idling at low idles, 100-400, and often stall. Disregarding that its a 97, Can anyone offer a suggestions on how to fix this problems or someone with similar problems tell me how to fix it? thanks alot.
(FYI). I replaced the factory air intake with AEM Cold Air Intake 3 years ago. It stalled for the first few days of the modification, but after I changed the hose and it was fine (idle was low but didn't stall) Now its acting up.
Old Oct 1, 2004
R1Style's Avatar
adjust the throttle cable or check to see if it's loose. If that's not the problem, take it to Honda and have them run a diagnostic... it could be a number of things.
Old Oct 1, 2004
JayFReaZy's Avatar
yea, check the throttle cable, and if it still continues, try reseting the ecu, if that continues then go to honda and run a diagnostic like ^ said.
Old Oct 1, 2004
Also try to clean the throttle body with cleaner and a soft cloth.
Old Oct 1, 2004
specter542's Avatar
I'm NeonImpact's a55hat!
specter542 should not be trustedspecter542 should not be trustedspecter542 should not be trustedspecter542 should not be trusted
vacuum lines
Old Oct 1, 2004
reddsunns's Avatar
thanks for the tips. will try it. hopefully it works
freyes23
Jun 21, 2015 10:37 AM
The Big Dutch
Jun 9, 2015 07:49 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
jakeconnor
May 5, 2015 07:30 AM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
