I will Replace my Tranny Will i need to....
Old Oct 9, 2004
ebencosme's Avatar
ebencosme has a little shameless behaviour in the past
I'm replacing my tranny cuz it's making a wear noise. A few months later i change the clutch (stage 3) some pleople say it's the throwout bearing and some, the front bearing and it only makes the noise when i release the clutch or ride it but when i hold it down it stops. I bought another tranny so my question is if i change it will i have to go to honda and reflash computer?
i don't want to bother those peeps
Old Oct 10, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
i dont think so...not too much on the tranny as far as sensors and **** there are a few but you should be fine....if anything your check engine light might come on then you may need to reflash
Old Feb 4, 2005
ebencosme's Avatar
yeah i just took it to autozone to diagnose the car and it was reading that the Air Intake Sensor was not working or Intake is receving too much heat i mean sometimes it goes off but mostly stays on so i think i will hav to replace the sensor and change the filter...
Old Feb 5, 2005
flotsamm's Avatar
You should always change the throwout and pilot bearings when doing a clutch job. Also the pressure plate and of coarse the clutch plate.
Old Feb 5, 2005
ebencosme's Avatar
i did all of that....
Old Feb 6, 2005
and perhaps have the flywheel resurfaced if you have a few miles on the car
Old Feb 6, 2005
ebencosme's Avatar
yeah i did that too i mean i went to a professional to do the job cuz i rather pay more than someone cheap that don't know what the hell is doing you know. I don't like too much people touching my car cuz my car is not a LEGO lol...
Old Feb 6, 2005
cmeias's Avatar
cmeias is an unknown quantity at this point
I had the same problem but it was just the through out bearing
Old Feb 10, 2005
ebencosme's Avatar
yeah now one of my friend has the same problem as me don't know why this is happening to this tranny i mean i changed my clutch but i never new this will happen it true that people say that this car are just for look not for horsepower....
Old Feb 11, 2005
SUPERFLY's Avatar
SUPERFLY is an unknown quantity at this point
A stage 3 clutch is way overkill and money wasted for your car. Are you sure they changed both bearings? Did you buy the clutch kit?
Old Feb 14, 2005
ebencosme's Avatar
well to tell you the truth i trusted on the last guy that did the clutch and since that happen never talked to him cuz i never got to see what he was doing i know one thing when he return me the car it was making a noise and guess what it was the mount was lose and he told me it was the heat shield of the muffler i almost fight him cuz he thought i did'nt knew about motor. i was telling him what was the problem and he goes to do another thing thas messes up since i gave the money he was an a$$**** but i will never put my car in a house garage cuz people for money think there the pros.. unless you do you're mechanic work to you're own car plus know what your doing
Old Feb 14, 2005
ebencosme's Avatar
well i suggest the people that do there tranny work just go for a complete clutch setup and never go further than stage 2 cuz our tranny are very weak. Now i'm spending double now cuz i had to get a used tranny and a whole new setup clutch and new motor mounts for my car.
Old Feb 15, 2005
_Viper_'s Avatar
Hey while your in there get a new throw out bearing never ever reinstall a tranny with out putting a new// Also get a OEM one not some cheap federal mogul one
Old Feb 16, 2005
ebencosme's Avatar
yeah i like my things to be done right the 1st time not the second even tho i made a mistake replacing that clutch without supervision
Jigee
May 9, 2015 11:18 AM
dosmastr
May 5, 2015 12:19 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
mazdamx3rs
Jan 20, 2002 07:38 PM
