wtf piece of shit 10a fuse - speedometer dead
Old Feb 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
wtf piece of **** 10a fuse - speedometer dead
ok, I ran over a curb (long story) and now one of the 10a fuses keeps popping in the fuse box underneath my steering wheel. The first time it blew was yesterday and my whole car shut off ... I pulled over to the side...
I was able to start my car again, but the battery light stayed on and my speedometer doesn't work ... also, my gas gauge goes crazy ... it'll goto low fuel, then 1/4 tank and just jump around. my friend found out that it was a fuse below my steering wheel (bottom row, four fuses from the left ... 10a fuse) and today it blew up again like a couple min after starting my car ...
can someone shed some light as to what is wrong?
Old Feb 16, 2005
flotsamm's Avatar
How does running over a curb have to do with blowing fuses? What kind of damage occured?
Old Feb 16, 2005
_Viper_'s Avatar
Stick your D(ick in the tail pipe and see if the fuse blows again....
Old Feb 16, 2005
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
Maybe the speed sensor went bad. Someone posted that it will blow the fuse and cause this problem. Check the wires UNDER the car, see if any got snagged.
Old Feb 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
flots: I don't know ... it wasn't a big curb
viper: you =
tin: will do ... I don't see how that would blow the fuse though
Old Feb 16, 2005
climacus's Avatar
climacus is an unknown quantity at this point
Something is shorting out. You need a mechanic who is good with the electrical system.
Old Feb 16, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
alright, I just checked out my engine bay ...
the primary o2 sensor was touching the header ... I pulled it off and it (obviously) ate through to the wire ... that was probably shorting something ...
I hope that's the problem ...
LorenzoC0395
Jul 14, 2015 08:46 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
ZILLA
Jul 5, 2015 05:24 PM
