Heater doesn't work???
Old Oct 28, 2004
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Hi guys. Okay, 02 Civic EX with a manual trans. My heat no longer works. I haven't the slightest clue as to where to begin. I will check fuses after work, but other than that, what could it possibly be?
Old Oct 28, 2004
Da1lyDr1ver's Avatar
does you engine get warm or does it stay at the cool level. if thats the case then you have to replace your thermostat.
Old Oct 29, 2004
maiden4ever's Avatar
maiden4ever is an unknown quantity at this point
ride your car real hard and see if you get heat, if so, try adding some coolant
Old Oct 29, 2004
2K1Civic17"Gabe's Avatar
seems like the car should warm up enough to get heat to you. turn off the circulate, and the a/c button, and turn it to heat. Should get all the engine heat. Thats what I do most the time when it gets cold. Saves gas and some people say it helps with HP. Takeing heat out of the engine bay, and into the car? not sure about that, but it should be hot anyways. Check your fluids like maiden said.
Old Oct 29, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
mm... dont expect any heat to come until the temp needles goes up atleast past the "c". Try driving for atleast 5 minutes. Also, I didnt know the heater needed a fuse. If you really want to feel the heat, as maiden4ever said, drive it hard and you'll get so much heat you would want to shut it off.
Old Oct 29, 2004
civic01vtec's Avatar
check your coolant level............could possibly be a HG......but i highly doubt it.
also could be the thermostat
Old Oct 29, 2004
another way to tell if you need more coolant, assuming your car is somewhat stock....just let it idle and if it heats up semi quick that also means more coolant
Old Oct 29, 2004
Old Nov 10, 2004
neat. i forgot about all these problems. i used to have them with my 190kmi 1986 integra. 55k miles later on the civic, im starting to have them.
i was driving very hard last nite on my way up to Cecil County Dragway to meet a member. all the way up I-95, i was averaging about 100mph. i had the AC off, vent open, and heat on blast, but no heat was coming in, it little or none.
When I get home, I will check my coolant levels and maybe the thermostat, but I doubt thats the problem because my car doesnt overheat or anything. The temp gauge is always between 1/4 and 1/2 way.
Old Nov 10, 2004
ren808's Avatar
ren808 is on a distinguished road
make sure you have no air in your cooling system. if you do this could cause abnormalities in the way your heatercore produces heat. remember to check for coolant level when the radiator fans are running. if they are not turn on; your ac. they will turn on shortly after. this give you true coolant levels
Old Nov 10, 2004
i'm pretty sure its your damn thermostat like i said before. just change the damn thing, it cost only $10 for a thermostat. change it and it could solve all your damn problems.
Old Nov 10, 2004
flotsamm's Avatar
Does it blow air out? If so then your heater blower is fine and it could be something wrong with your heater core. If you dont feel any air coming out it could be a bad blower. Or you could have a bad or clogged heater core if you feel air blowing but its not hot.
Old Nov 11, 2004
NoToRiOuSxPiNoY's Avatar
Sekz God
NoToRiOuSxPiNoY is an unknown quantity at this point
^^ could be your heater core or thermostat. Check your thermostat first..
Old Nov 15, 2004
Thermostat checking will commence today. I have such a horrible schedule, and dont get time to check up on this thread, let alone fix the problem. Thanks for your help guys, I will keep you posted with results after thermostat change.
slynger
18
May 8, 2015 06:06 PM
ORskier
May 3, 2015 12:54 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
darwin-t
Apr 18, 2015 09:29 PM
blackbullet
Dec 1, 2001 03:44 PM
