Replacing wheel bearing on 2001 Coupe EX
Old Aug 16, 2004
silverrazor's Avatar
silverrazor is an unknown quantity at this point
Unhappy Replacing wheel bearing on 2001 Coupe EX
Howdy folks!
Just wondering if anyone out there has ever changed the wheel bearings on their 2001 Civic EX Coupe. About 10K miles ago, I started hearing this funny sound from the front driver side. I was sure it was due to bad tires, so I drove it until I needed to change the tires. Well, 10K later...I changed the tires and the darn noise is still present.
I brought it into the shop and the tech told me it was a bad wheel bearing on the driver side, front wheel.
The lowdown: $68 for parts, $130 for labor.
Is this a do-it-youself, or shall I let the shop take care of it?
Any info would be wonderful....THANKS!
My ride: 2001 Satin Silver EX Coupe (99,600 miles; 36mpg)
Old Aug 18, 2004
sam777's Avatar
sam777 is an unknown quantity at this point
i had to get mine done....its due to hitting like a curb or something most likely....and that price seems about right for the part... but the labour seems kinda bit much....yah it aint cheap but its better than risking your wheel flying off while driving hahaha
Old Aug 18, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
ask your local mechanics for price. It sounds like it takes honda 1.5 hours to fix it. Given that it is $90/hr labor.
Old Aug 18, 2004
sam777's Avatar
i didnt bring it to honda...i brought mine to a shock and strut specialist and they did it in 1hr easy....none of that dealer mark up....call around you'll find cheaper and i wouldnt recommend doing it yourself cuz you gotta take out the springs and stuff unless you have the tools and know what your doing.
Old Aug 18, 2004
civichxtreme's Avatar
civichxtreme is an unknown quantity at this point
yeah you cant do that what you can do if you have an extra vehicle is to take the wheel assembly off and then take it somewhere to having the bearing pressed off and on. That should save you some labor charge
Old Aug 19, 2004
eddie5spdx's Avatar
eddie5spdx is an unknown quantity at this point
hey silverrazor are the wheel bearings you're buying factory or aftermarket???
cuz my rear ones are sounding really bad.
Old Aug 20, 2004
Thanks for the heads up. I'll drop by some shops and let y'all know what goes down.
Late.
bo_red
Transmission
May 3, 2015 09:14 PM
Dorval Andre
May 1, 2015 09:37 AM
oneheadlight
Apr 29, 2015 11:30 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
