7443 & 7440 bulb the same??
i ordered a bulb to replace the rear tailight for bulb 7440 but they said that 7443 is the same as 7440 and replaces it but whenever i put the bulb in and test it i keep blowing a fuse. its for the turn signal by the way. the stock bulb has like a black clip attached to the bulb but the one they sent (7443) does not have one.
i feel so frustrated
i feel so frustrated Joined: Sep 2002
Not te same. 7443 is dual filament for our front parking/turn signal. 7440 is single filament for rear signals and sedan reverse lights.
My bad, yea, 7443 is the dual filament for turn signals. I kept thinking otherwise because of these GE bulbs I bought for my turn signals that stay lit up while my headlights are on, and I replaced them with the bulbs that I bought from those visionbulbs.com people. 7440 is what shows on the GE box though. The visionbulbs don't say what they are.
I can only see a difference in that the bulb is smaller sized and has sort of a seperate plastic housing on the bottom as compared to the regular GE bulb.
Re: 7443 & 7440 bulb the same??
you need to make modifications. a 7440 can fit in a 7443 socket but you need to grind down the glass knubs on the bulb with dremel. im not sure about the other way around. i dont know why you would want to fit a dual filament bulb in the reverse lights. just use a 7440 (or 921 for coupes).
cferry7
Oct 18, 2015 06:32 PM
meicalnissyen
Sep 25, 2015 12:12 AM
shaejb15
Sep 12, 2015 01:02 AM
MamaBear2015
Sep 4, 2015 09:04 PM
