2002 Civic - headlight bulb recommendations?
Old Sep 4, 2015
MamaBear2015's Avatar
MamaBear2015 is an unknown quantity at this point
We just got this car and the low beams are dull while the high beams don't work at all. So first I want to check the high beam filaments, but then I was thinking of just replacing them. Looks like these are 9003 units.
So if I want to pay a little extra and get the maximum brightness ones ( not HID - just standard ) which ones are good for that?
In other headlight bulbs I've seen, instead of paying $20 for a bulb, you could pay $25 or $30 and get ones that were 25% brighter or 50% brighter.
I don't want special white or blue spectrum ones, because I talked with a cop years ago and he said that the blue ones might not even meet DOT standards and that the yellow range spectrum of standard bulbs are actually better for seeing at night, because yellow bends around curves and corners in the dark better.
So what's good, group?
Old Sep 4, 2015
lowlife9's Avatar
Re: 2002 Civic - headlight bulb recommendations?
Phillips Extreme bulbs are the brightest legal bulbs you can get sylvania bulbs are not brighter there just whiter also look into PIAA bulbs.
Old Sep 4, 2015
Thanks Lowlife. Not sure what PIAA are.
Old Sep 4, 2015
Found Philips 9003 XPS2 X-treme. The only problem appears to be that no one carries them locally in Denver. I see them on amazon.com inexpensively, but want to pick them up locally soon.
Old Sep 4, 2015
lowlife9's Avatar
PIAA are a bulb manufacturer that are extremely well built but not legal i don't believe and they cost an arm and a leg. i would just order the phillips online you don't really have a choice.
Old Sep 4, 2015
Looks like they're legal - I see them now.
Old Sep 4, 2015
lowlife9's Avatar
order the phillips and see how you like them if there not what you want then step up to PIAA if you don't mind the price just make sure you order from a certified dealer because there are alot of fake ones floating around.also remember the more power you get out of a filament bulb the less life it will have.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
bsmiley
Apr 27, 2015 01:27 PM
shaejb15
Apr 26, 2015 07:44 PM
smmahan
Apr 15, 2015 08:17 PM
