my RPM's are fugged up
I've been having problems with my RPM on my car. I drive an auto and everytime I am at a light or stopped the RPM's are at .5 and then engine starts to struggle and sound like its about to die. It kinda feels like I would be starting up my car in the winter time during a storm. do any of you guys know what the cause of this is? do I need a new battery? vacume line?
Adjust your throttle cable. See DYI. http://www.7thgencivic.com/forums/sh...d.php?t=154952
Originally Posted by gearbox
See my sticky for adjusting idle and throttle cable.
thanks for the help guys!
My car did this right after I swapped the TB and didn't do the idle relearn. I reset the ecu and let the car idle 5 mins after warm, and now it's perfect. If that doesn't work, try the idle adjustment. It will fix your problem most likely, but be careful adjusting it too high. You can turn the screw with the car on, since all it does is open the valve more. Just don't do too much or the CEL comes on.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bruce2
Sep 27, 2015 08:45 PM
NROD315
Sep 23, 2015 03:46 PM
Juanb24
Sep 15, 2015 12:39 AM
