- Rough Idle Cold???
- Issues after Installing Speakers
- engine dead
- car starting probs
- Driver AIRBAG?
- RPM @ a cold start
- What is making this noise?
- Honda logo on valve cover?
- Power Steering?
- HELP stripped bolt on cat conv. while changing exhaust
- Clutch problems
- Terrible Gas Mileage
- MT problems??
- Problems Already??
- Oh look another auto transmission dead. My legacy.
- Speedometer fluctuation?
- Car Problem, Fuel System
- stock airbox broke!
- Water problem!
- clutch feels "funny"
- exhaust
- are they ever going to stop leaking?
- Problem with angel eyes headlight
- problem with exhaust...
- Leaking Rear Brake Cylinder
- please help! blinker problem
- Car has good and bad days?
- high-pitched whining sound on rainy days
- help with a squeak noise from the engine?
- Minor Interior Notables on EX Sedan (02 vs. 04)
- My car Hesitate??
- Power Locks Don"t Work
- car shaking like mad? need help *UPDATE need even more help!
- Clutch or transmission problem
- Auto Transmission gone to heaven
- weird muffler angle...
- 2001 head swap on a 2002
- **6 recalls on CvC's**
- tranny problem.please read
- wierd sound....
- car heavy and sluggish? u too?
- rpms are bouncing
- sign this petitions (si ans rxs tranny prob)
- warranty bs
- malfunction indicator lamp problem
- 03 and 04?
- Stock radio problems
- Ruined interior!
- Warranty Covered????
- headlight switch recall
- exhaust problem
- body paint fade
- 02 typeR grill on 03
- HELP gas lever..
- Driver-side auto-Lock won't go down or up
- DIY: Hood rattle repair.
- Cars Freaking Out!! Need Help!!!
- Chug a Chuggin
- struts blown at 20k miles
- Burning smell
- popping sound from engine bay after fipk II
- J/W if checking breaks for wear/problems is for free
- glovebox rattles, notice?
- Rage!!! *56K Go Away*
- Dash gauges making noise?
- Header Heat Shield
- i need a list of what violates warranty
- Does ANYONE know what this is?!?
- Popping out of 5th gear after clutch install
- Why does my car jerk?
- AEM V2 Intake broke at the braket
- Downshift by mistake
- Heres a stumper
- What to do with that nasty seam under the doors.
- Chrome Strip Removal - HOW???
- removing plastic wheel well?
- revs dropping below 500
- Running lean???
- headlight fogging
- S mode on CVT<<<
- The recall and projectors/HID
- Im Sick Of It!!!!
- Drums
- Hoods
- Does a 2002 LX Lower Panel fit an 01 EX?
- clutch issue
- Vibration while braking...
- clunk clunk clunk...
- CARBON FIBER HOOD issue...
- check engine light code OBDII
- 40 PSI on my 04 from the factory!!!
- HELP! thread for lugnut is messed up
- turning light
- Need a new transmission
- My girlfriends Neon...
- Loose rattling sound under passenger floor
- Steering wheel lock?
- maintanence required repost
- Battery Acid Spill. Help!!!
- 01civic wont start.
- Transmission is FUBAR
- Clutch Is Deadddd!!
- bad luck or what?
- whats up with our paint?
- the air stinks inside my car???
- HELP! I cant rev past 4k
- overheating why
- sound when i shift ...
- Been nice reading this board . . . I've sold my Vic
- Safety Recall ALL 2001 civic's some 2002 civic and Hatchbacks
- Cancel warranty
- Gas door problems
- ac wont turn on?
- knocking noise when i turn the steering wheel
- vibrates when cold start!
- Prob w/ car almost caused 3car accident need help
- Excessive oil consumption on new 04
- nasty rattling from dash?
- torn up caliper piston boot
- TPS Problem
- Updated TSB bulletin 02 clutch noise
- Help!! Car Backfiring!!!!!
- 8,000 mile Maint. Req. LIGHT
- car start trouble
- Clicking noise when accelerating
- Grinding Noise from front of the car
- Automatic Transmission problem...HELP!
- Simple Oil Question
- 2001 Trunk Mat Problem
- broken power door locks
- was there a 10k or 15k check up? ...
- Is My Clutch Done For!????
- Door and window rattle
- im gonna hit 30k miles
- unusual smell when accelerating
- automatic trans question
- A/C and heating
- Map Sensor Connector Broken Wire
- Problem with your Heater? BLOWN HEAD GASKET!
- weird nose at high speeds
- my radio stolen, ne 1 knoe how to install a clip?
- Advice needed
- How many miles from OEM Pads?
- whos says theres recalls on our civics!!!!!!!!
- Gauges Fading in and out
- WINDOW SHATTERED.. HONDA won't help as always
- Strange brake grinding condition
- The mysterious whistle problem
- looks like rust oozing out of my spark plug coils....
- Thumping noise when turning and making U-turns? Need help?
- Hey cool, the bumper's peeling
- Car Lurching, turning off... Help! *UPDATE*
- kaminari side skirt getting caught on door
- touch up or not? (looking for a different way to fix scratch)
- Vibrating Problem
- rattling coming from somewhere
- Front Brake Question
- Rattle when idling coming from clutch mechanism?
- Engine Problem...
- Thinned out oil...Potential Problem?
- AC light?
- Does anybody else have any annoying rattles in the interior from their exhauist?
- 2003 Civic Recall (Automatics)
- Clicking Noise When I Back Up
- Steering wheel shaking
- Heat shield rattle help!!
- Honda Low Beam Headlight Recall
- Question bout rear bumper
- Stupid SRS light
- 2004 Factory Lip Kit Cracking
- normal coolant loss?
- Clicking Noise In Engine ?? What to do..
- ac dont work
- rattles when accelerating
- Air Conditioning Compressor
- transmission wont shift??
- Broken Slave Cylinder...WTF?
- maintenance light? to Ronin
- Hood Rattles like a BI@TCH!
- weird sounds
- Clickin Noise
- Bogged Acceleration..
- Tips For Better Gas Mileage
- Hesitation in Acceleration..
- Help with Alarm Scanner, please
- I can't take this sh!t anymore!!!
- 2nd gear clicks
- Fuses?!
- My car stalled and died while makin a turn!!!
- serviceable joints
- When to change brake pads
- lower ball joint boot split at 41,000 miles
- subfrmae question how much?
- Firestone Recalls
- Normal current draw when car is off?
- whats going on w/ my car
- Gas Door
- left turn signal gone crazy!
- Squeaking front suspension - due to poly bushings?
- window lockout button
- How do I oil my bearings?
- Popping sound on cold engine 01 Coupe
- Oil pan "wet"?
- Some Punk Dented My Car!
- Hood Not closing all the way
- whats broken?
- Parking and Tailights Out
- Parents just don't understand...
- Crunching front squeaking back
- Power Windows
- Man't Req Light
- Anyone had the same problem I had with the motor?
- Popping out of 2nd gear.....
- right turn woes
- Clunk Sound when Braking is normal?!
- has anyone else had this problem?
- Oil has strong Gasoline smell....
- is normal to your 02 civic?
- Whats wrong
- Help Asap!!!
- oil leek????
- Tranny is GONE!
- oh snap
- Dead Battery?
- Side Air Vents
- CEL Problem Solved!
- Best way to remove stupid decal??Plz Help!!
- 2 interior questions
- re-fill coolant
- o2 sensor heater control?
- Heater Overheating
- air filter box screw
- shocks(struts), low control arm bushings
- TSB help
- Anyone else's seat alignment off?
- rattling noise,,no help from honda
- Smell of gasoline in the oil....
- Srs Dashboard Light, Wtf?
- Problem with heat
- problem with driver sided headlight
- Car Shakes
- foggy windows
- change or flush coolnat/anti-freeze
- Im havin Problems
- close
- WTF!?!?Need help FAST! Headlights...
- muffler burn?
- wierd engine noise
- Idiling Problem Need Help!!!tps
