Thinned out oil...Potential Problem?
Old Mar 10, 2004
Dticalman01's Avatar
Dticalman01 is an unknown quantity at this point
Unhappy Thinned out oil...Potential Problem?
Hello guys...I think i got a problem. Whenever I check my oil..and wipe it on a napkin..it smells of gasoline.. But a bigger problem is that the oil is loking more thinned out as well.. I dip the dipstick and the oil sorta glides on the edge....above it, it's jus clear i guess...it's looking more thinned out...the oil only has about 2000 miles on it too and it should be in good shape as well..My acceleration is slow..don't know if that has anything to do with it..but could this be a potential problem..? Should I get an early oil change with a 5-30 oil..have any of you guys experienced something like this...? please help. lease:
Old Mar 10, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
How do you know the oil is thinned out just by looking at it?
Old Mar 10, 2004
The oil is half invisible...doesn't cover the dipstick it's almost half invisible and extra thin, extra light color...
Old Mar 10, 2004
cambo's Avatar
I wish I was asian
you're not checking your oil after the engine is warmed up are you?
It WILL get thinner as it warms up.
Old Mar 10, 2004
Man you've got problems. Just switch to synthetic and see what happens. My regular oil is fine, but I think you have some engine seals that are leaking.
Old Mar 11, 2004
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
the only way to be sure is to get an oil anyalisis.
http://www.blackstone-labs.com/free_test_kit.html
very reputable, $20....worth it, can give you some vital info
Old Mar 11, 2004
I didn't want to edit because you guys should know that blackstone labs also does analysis on transmission oil and differential oil. my friend just got his sent, its worth it, they can tell if there is a problem.
mohawkboom
67
Aug 25, 2015 12:28 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
ZSKCivic01
Detailing
Dec 27, 2001 12:46 PM
MyCivic
Dec 19, 2001 02:09 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
