torn up caliper piston boot
Old Mar 27, 2004
bluericeburna2k2's Avatar
bluericeburna2k2 will become famous soon enoughbluericeburna2k2 will become famous soon enough
Angry torn up caliper piston boot
i just changed my civic's front disc pads this weekend. i noticed the driverside caliper piston boot is ripped up. ive never changed thoes boots or even know how much they cost. is it worth it to bitch to honda about it or should i change it myself?/
Old Mar 28, 2004
tfnaaf's Avatar
BLDNPSI Mod
My question is, was the drivers side brake pads worn more then the passenger side? You said it was torn but did it show damage from heat? If so i recomend replacing both front calipers. Its possible that the drivers side caliper was dragging causing the excessive heat and then resulting in the boot to come apart.
As far as changing the boot they typically are not too tought to install see picture below
Part = 368867 001 CALIPER SET, FR. (AD51-14) NO COLOR $13.01
From
http://www.hondaautomotiveparts.com/...y5=FRONT+BRAKE
Old Mar 28, 2004
the pads were pretty worn. both driver and passenger sides were worn the same. i think the boot rubbed against teh rotor as i pushed the brake.
Old Mar 30, 2004
ELaudio's Avatar
ELaudio is an unknown quantity at this point
Changing the boot on a caliper isn't an easy job, but it is do-able. Best thing to do is remove it from the brake line, take the whole thing apart, clean every part, replace all the seals/boots and put it back together. That's basically what you're getting when you buy a rebuilt caliper.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
Junquito89
Sep 27, 2015 10:22 PM
bashea
Sep 15, 2015 04:59 AM
