Automatic Transmission problem...HELP!
I was comin down this huge dip in the road and went over a chunk of curb or stone or something, I have a 2'' drop, needless to say it scraped and bumped all over the underside of my car. Ok, so everything seems ok, body kit not hurt, all my piping seems fine, but there's definetly somethin goin on w/ my tranny. When I shift the tranny from park to reverse, the stick is in between reverse and park even though I'm in reverse and my gauge cluster also indicates that I'm in reverse. When my car's in drive, the stick is in between drive and neutral, even though the cluster indicates I'm in drive. WTH is goin on, my car's not under warranty, I really need help. Thanks.
When the stick is in between gears, do you actually feel that it is held properly inside the notch? Or is it actually in between notches?
If it is inside the "notch" then I don't think it's that serious. I'm guessing that the gear indicator next to your shifter just got knocked out of position.
you probably messed up your tranny from the rock you hit. jack up your car and take a look around. honda will definately not fix it for free even if your car is under warranty if you caused it, i.e hitting the rock.
The trans is probably ok, but as for aligning the indicator back up, I'm not really sure what that would involve.
knknif
Aug 4, 2015 06:11 PM
viperGTS
Jul 27, 2015 08:38 PM
Smokahontas123
Jul 22, 2015 10:07 PM
Q-Bert
Jul 19, 2015 09:09 PM
