Steering wheel shaking
My steering wheel shakes back and forth when i brake from driving on the freeway going 70-90ish. at low speeds it doesnt shake when i brake. at first i thought it might be low air in my tires, but i pumped them and its still a problem. is this something i should goto the dealer for or is there something i can do about it. thanks in advance.
sounds like you having a brake problem. go and have your brakes checked, because I have always heard that if you stop and your steering wheel shakes, something is wrong with the brakes.
Originally posted by Kloverz
its not always the brakes or the rotors, sometime its just the rims is not balance, but if its not that then it will be ur rotors.
If the problem was unbalanced wheels, his steering wheel would be shaking at highway speeds regardless of whether or not he was braking.
yeah i have the same problem but it shakes when i'm on the fwy too....
do u have rims? cuz i noticed that after i got rims
i'd thought since the tires are thinner than stock, we feel the bumps more ya kno
If it is happening at highway speeds and not when braking, it is most likely your tires are out of balance. Simple fix, get them balanced. It is not your brakes.
If it is pulsating under braking, most likely your rotors are warped. Have them turned out or replace them.
OptimisticWay
46
Oct 15, 2015 02:16 PM
qlitten
Jul 21, 2015 03:12 PM
