Will The Wheels Fit?
Old Oct 1, 2015
Tedverseti's Avatar
Tedverseti is an unknown quantity at this point
Hey guys, I'm in the process of doing the suspension/wheel set up on my 03 ES2 & I have a quick question. I found a pair of Rota Grids (16x7; 4x100; +40 offset; 67.1 hub size). However, the person selling them is telling me that they won't fit my car. I've been looking into wheels for a while however & I've found plenty of others in this forum with similar wheel specs. Since this is my first time buying new wheels, I'm not knowledgable enough to know, but do the wheels actually fit my car or not & if so, would anybody know the size of the tires I need? I can't seem to find that either. I'm going to be dropped on Koni Yellow struts w/ Ground Control coilover sleeves, at about a 2.5 inch drop. Thanks!
Old Oct 2, 2015
GolNat's Avatar
Prelude Owner
Re: Will The Wheels Fit?
It will fit with some hub centric rings. The bore size is larger then the Civic's which is 56.1 I believe.
Old Oct 2, 2015
Tedverseti's Avatar
Thanks man . Any idea on the tire size ?
Old Oct 2, 2015
GolNat's Avatar
Prelude Owner
Tire size you will want to keep it at a size that has the same or close to the same rolling diameter as your OEM wheel/tire package. This is important for keeping the speedometer and odometer accurate. If you don't care about that then matching it as closely is not as important.
Calculator for you:
https://www.tacomaworld.com/tirecalc
Old Oct 2, 2015
most 225 will not fit, unless crazy off-set?
Old Apr 23, 2020
Andym's Avatar
Andym is an unknown quantity at this point
Will a taller tire than stock affect the transmission gear shifting? For example lx was 195/60/15 and I have had 205/65/15 for 2 years or so and I know the speedometer is a little slightly off, I was wanting a taller tire 195/70/15 to get lower rpm on highway and better mpg. So I want to install tires at Costco this time but they won't allow me to install anything other than exact stock size
Old Apr 23, 2020
Colin42's Avatar
Find a shop that will
BootyDo
Jun 21, 2016 03:45 PM
stvpagn
Jul 9, 2015 09:59 PM
jferristx
Jul 8, 2015 10:09 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
