Problem with heat
Old Feb 5, 2004
HEBEGEBZ's Avatar
HEBEGEBZ is an unknown quantity at this point
Problem with heat
Is anyone else having a problem heating up their civic? Mine only starts getting warm after about 15-20mins. Thats if the car is moving. Sitting still takes longer. Anyone knows something I can do to fix this problem. Maybe I need some sort of service done. I don't know.
Old Feb 5, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
I understand what ru talking about cause mine is the same it would get warm til 20min or so.
Old Feb 5, 2004
Da1lyDr1ver's Avatar
that doesnt sound right that it takes so long for the car to warm up. most of the time the problem has to do with the theromstat. its a pretty easy fix if you know what you're doing but is kinda messy. so yeah, get a new theromstat.
Old Feb 5, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
sounds normal to me. When exactly do you turn on the heat? Do you let the car fully warmed up before turning on the Heat?
Old Feb 5, 2004
flotsamm's Avatar
20 minutes is way to long. Our cars reach operating temp pretty quick, usually within the first few miles at least thats what mine does. Sounds like you thermostat as mentioned above.
Old Feb 6, 2004
HEBEGEBZ's Avatar
how much are we talkin for a new thermostat (labor and parts)
Old Feb 6, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
You referring to the idiot gauge on the dash? HA. That POS reads full temp at 125 deg. The thermostat pops somewhere around 180-185 and the car eventually ends up at 205-210. I'd say it takes a good 3-4 minutes of driving to hit 180, then maybe 4-5 more minutes to open up to 205, maybe 10-20 (or more if its cold) if you idle it to warm up. Its not very quick, the gauge in the dash is pretty misleading. It says the same thing at 220 as it does at 125.
blazebrown
18
Jun 2, 2019 12:31 PM
cooldan1
Apr 23, 2015 10:49 AM
AnotherDopeStyle
Jan 28, 2002 12:51 PM
Aznnp77
Jan 6, 2002 08:41 PM
