car starting probs
Old May 15, 2004
car starting probs
Hey guys,
Recently after I just bought an optima yellow top, the car is having trouble starting on a few occasions. Sometimes it would crank 5-10 times and not start. Then I try again and it sounds like it's stalling before finally starting up. I even turn to the on position for a few secs to build fuel pressure.
Do you think it's the battery? I'm gonna test it. Also, my stock airbox is loose. A couple screws won't tighten down. Would that be the problem?
Old May 17, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
I'm guessing that it is the battery, since the problem started right after you switched. Did you verifiy if everything was connected back properly? Next time you get an oil change, ask them to test the battery for you ... or you can do it yourself with the right instrument. Takes 30 seconds.
A slightly loose airbox probably won't be a problem, but it may cause annoying rattles in your engine compartment.
Old May 18, 2004
Well the voltmeter reads around 12.5V when the car is on, but not started. And now I do remember this happening with the stock battery every so often. Some days it will start strong, then other days it will barely turn over. Is it fuel system related? fuel pump maybe?
Old May 18, 2004
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
It could be your ECU code error. I used to have the same problem when cranking. After I took it to the dealer, their labor description says "wrong input code, re-inserted code". The car is been rock hard even on average cold days. Unless its really below zero, then it would be hard to turn over. Which is normal for all cars because of aluminum being shrinked.
CarStuff
Dec 6, 2020 12:52 PM
dragonsblood
Apr 27, 2015 12:28 PM
Blaster30
Apr 22, 2015 12:21 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
