Water problem!
Water problem!
I was wondering if you guys have had problems with water entering the cabin on the driver's side? I don't know where it is coming from! Is there any chance it could be coming from underneath the car? I ask that cuz 1 time i wasn't payin attention where i was jackin my car up and made a little hole in that stuff that covers the metal? Could that be the problem?
THanks for the help
THanks for the help
as long as you lifted you car along the jack points (looks like rails) then you should be fine. the rubber stuff comes off even if you dont jack your car up. where is the water at? someone else was having a problem with water entering their drivers side floor and found out it was because his windsheild was leaking or something.
i posted a thread about the exact same thing but noone had the same problem as me. my driiver side back seat carpet is discolored and wet. i never left the windows open in the rain or spilled anything down there.
im gonna get my car checked out by honda soon.
"When do you realize water is coming in? If this only happens during rain, then your problem is the mouldings. If this happens on a sunny day and dry roads, then the drain hole in the bottom may be plugged or the ductwork cracked or broken."
Word_
good advice, ....
how do we check the moulding for leaks?
Word_
good advice, ....
