Crunching front squeaking back
Old Feb 18, 2004
MRB068's Avatar
MRB068 is an unknown quantity at this point
01 civic 2dr ex. Recently I have been hearing a crunching type noise coming from the front pass side. It happens when I go ever speed bumbs, or large bumbs in the road. It does not happen when I hit minor bumps. Also my back end is squeaking like crazy. Any type of bump it squeaks, just sitting in sometimes makes it squeaks. I took it in to the dealership they told me it was the rear sway bar and replaced it, but as soon as I drove away the sound was there.
Old Feb 18, 2004
robbclark1's Avatar
Retired suspension supermod.
yeah mine squeaks because of the sway bar. Do you have any mods?
Old Feb 18, 2004
AnyTym01's Avatar
AnyTym01 is an unknown quantity at this point
Mine did the same thing. I just raised it up and covered everything that moved with WD40 and it has been quiet for about 4 months
Old Feb 19, 2004
MRB068's Avatar
No mods, what about the front crunching?
Old Feb 20, 2004
robbclark1's Avatar
hmm there may be something stuck around the spring or stuck in the suspension. I am not sure. Have you looked at it? If you are under warrenty, take it to Honda. If not jack up that side, take the wheel off, see if the shock is leaking oil or there is something amiss with the spring and shock. make sure all bolts are tight and possibly torqued down to the right specs. Specs can be found in the suspension performance forum.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ghondavic
Transmission
Apr 12, 2017 09:37 PM
TheRubixHorse
Apr 17, 2015 08:55 AM
GH04si
Apr 15, 2015 08:13 PM
BabyLX
Nov 16, 2001 05:53 PM
