HELP stripped bolt on cat conv. while changing exhaust
Old May 14, 2004
g33s0n6656's Avatar
g33s0n6656 is an unknown quantity at this point
I changed my exhaust just now and one of the 3 bolts on the cat somehow very easily stripped out on me! ahhhh what should i do? Should i leave the two there and order an aftermarket cat or drive it for 3 days with the two bolts till i can get to work and use a torch to heat it and hammer out the bolt since it is pressed into the cat i have an 03 si leave some advice please
Old May 14, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
i would drill out the stud and just use a new nut and bolt in its place.
Old May 14, 2004
Vinh's Avatar
get a stripped bolt remover kit
and buy a new bolt
Old May 14, 2004
civic01vtec's Avatar
how is it stripped?
did you over torque it or cross thread it.........is the head rounded off ??
Old May 15, 2004
g33s0n6656's Avatar
the bolt is a pressed fit into the stock cat then the exhaust is butted up against with a nut securing that on it must have cross threaded cause they are all f**** up i hack sawed off the remainder of the bolt and then drilled a hole in it and it still didnt wanna come out i dont wanna drill any bigger cause i dont want the original hole messed up (i wasnt exactly centered (hey would you get it centered with a foot of room under the car to work with?)) I think after i get off work sat afternoon im gonna stop up at the nearby gas station and give em 20 bucks to heat it up and pop it out This was all a learning experience i guess thanks for the suggestions guys
docmartin14
Jul 30, 2015 11:26 AM
BootyDo
May 7, 2015 04:46 PM
Grey
16
Jan 27, 2002 11:34 PM
silvervtec01
Dec 9, 2001 08:50 PM
colombianDXcivic
Bolt-on Engine Performance
Nov 22, 2001 03:17 PM
