Hood Not closing all the way
Old Feb 21, 2004
silverem2's Avatar
Question Hood Not closing all the way
Ok, so when I close my hood, it closes all the way, meaning that it doesnt like come unlatched but i can lift it a little bit and its got that gap where i can lift. Its getting really annoying cause it sounds like a bad rattle when i go over little bumps. Anyone know what to do?
Old Feb 21, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
what kind of hood, Oem, CF hood, you should check ur hood lock,
Old Feb 21, 2004
silverem2's Avatar
Oem, like theres a gap that you can lift up about this much ______, but its just enough so thats its damn annoying. Can i adjust it or something
Old Feb 21, 2004
Kloverz's Avatar
you can try this on bothe side there is a black rubber bolt screw it and see if that work, also you can adjust the lock there will be like i think 4 screw losen it and move it up or down see if that helps,
Old Feb 21, 2004
silverem2's Avatar
Its night already so ill try it tommorow. If anyone has any other ideas, please, post.
Old Feb 22, 2004
silverem2's Avatar
any other ideas that i can try while im out there?
Old Mar 6, 2004
Pibe54's Avatar
Pibe54 is an unknown quantity at this point
i have the same problem, ive been an accident so i thought it was that, just play your music loud, you wont hear a thing. I tried that black rubber thing too, helped but didn't get rid of it.
Old Mar 22, 2004
blue03ex's Avatar
blue03ex is an unknown quantity at this point
Had the same problem. The hood latch/release mechanism can be raised/lowered. I had it in for inspection, and had honda tighten it up under warranty.
SammySC
121
Apr 7, 2017 07:43 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Bikergofast
Detailing
Nov 20, 2015 02:34 PM
rnaodm
Sep 21, 2015 12:42 PM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
