im gonna hit 30k miles
Old Mar 21, 2004
fordfocussucks's Avatar
fordfocussucks should not be trusted
Lightbulb im gonna hit 30k miles
where should i take it? and how much did you guys pay?
Old Mar 21, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
DIY! heehee... I think most automechs should be able to do these things....
Old Mar 22, 2004
DaveyD's Avatar
Mr. Negative
DaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the roughDaveyD is a jewel in the rough
Take it to your own garage and do half the stuff they list as "check or inspect" and do that yourself. Thats what I did. Save yourself the cash..
Old Mar 23, 2004
I dont know nothing about cars
Old Mar 25, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Take it to whoever you trust to undo 3 bolts and an oil filter. All you really gotta do is change the oil and the tranny fluid. If your plugs seem cruddy you can change them, and look at your air filter.
Check the coolant level by looking in the over flow tank to the right of the fan.
Thats really all you need to do.
All you need is :
4 Quarts of oil + Filter
2 Quarts of Tranny Fluid
4 spark plugs
Maybe some 50/50 coolant mix
An Air filter if you got the stock one
Thats really it.
I wouldn't give someone more than $80-$100 to do it all. Try and con a friend into helping you. Pay for parts and beer.
Old Mar 25, 2004
Ronin's Avatar
Ronin is an unknown quantity at this point
It's unlikely that the platinum spark plugs would need changing at 30k (they're supposed to last at least twice that long), but it wouldn't hurt to look at them, I guess.
Everything else Boiler said sounds about right.
Old Mar 25, 2004
2k2EXCOUPE's Avatar
TUCKIN 19s
Auto tranny fluid needs to be changed at 30k? Seems REALLY early...also seems early to change spark plugs unless there is an issue.
Old Mar 25, 2004
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
I have a friend that works at a Honda Dealer in the service dept. and he got me the 30K service for around $200. I know about cars but I wasn't about to go wrenching with my car and possibly screw something up then I would be f*****.
Also it will look good when I try to sell my car and show the person that I had all of my oil changes and maintainance done at the dealer.
If you have the money, get it done at the dealer.
Old Mar 25, 2004
Jap-Euro Fusion
Auto may be 60... but manual is 30K for sure. I pulled the plugs too, they didn't look so nice... rather than mess around and try to figure them out, I just swapped them. Doubt it did much, but it wasn't all that expensive to get a set of Platinum +4s.
Old Mar 28, 2004
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
fyi, auto trannies need to have their fluid changed more often the manuals. about the 30k miles, you should always get in the habit of doing preventative maintence. changing fluids regualarly prevent more expensive problems from happening[list=1][*]oil and filter (if not done within 3k miles)[*]rotate tires (this can be done by you or a friend)[*]check air conditioning filters[*]replace engine air filter[*]replace spark plugs (single tip bosch platinum will do just fine)[*]flush radiator or engine block/radiator[*]change tranny fluid[*]check brake pads[/list=1]
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
beachglass
May 22, 2015 09:59 PM
pheaton
May 4, 2015 08:26 PM
Readypro
May 2, 2015 12:23 AM
