Excessive oil consumption on new 04
Old Mar 28, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
I switched to Amsoil 0-30-the recomended replacement for 5w-20 in my o4 EX. After a week its used almost a quart! Thers no leaks. Theres 1500 miles on the car. Cant possibly be that much blowby?
Old Mar 28, 2004
03white5spd4d's Avatar
03white5spd4d is an unknown quantity at this point
whos doing your oil changes check the bottom of your oil pan, with the car off touch it and see if there is oil film/buildup caused by undertorquing the drain bolt. Are new crush washers being used, and look at the oil filter....is it leaking maybe because it wasnt properly tightened
Old Mar 29, 2004
redvtec04's Avatar
VTEC MASTER
I layed some newspaper down and parked it in the garage overnite. Nothing
Old Mar 29, 2004
i would still look at the oil pan, also you could be leaking oil and you splash guard might be catching some of it. who does your oil changes??
Old Mar 30, 2004
xkimsungminx's Avatar
xkimsungminx is an unknown quantity at this point
could your car just be a lemon?? any chance?? cuz i got the 2004 civic ex coupe manual.. and i have no problem what so ever with getting good mileage on it haha.. it's great getting such good mileage when gas prices are this high
Old Mar 30, 2004
CK's Avatar
CK
CK is an unknown quantity at this point
Do you have white smoke coming out of your exhaust?
Old Mar 31, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
i do my own oil changes.....just change my car's oil for the 2nd time.....the amount of oil that drained out, was exactly how much i put in the 1st time 3 3/4 bottles
Old Mar 31, 2004
flotsamm's Avatar
If your burning oil excessively you'll see blue smoke coming out the tail pipe.
Old Mar 31, 2004
me 2. i do my own oil changes
  • mobil 1 5-w20
  • new crush washer
  • honda oem filter
  • drain plug torqued (to i think 33 ft/lbs)
i never had less oil than i have come back in, if you are burning oil your exhaust fume color should be purple, white signifies antifreeze. if you think it blowbly, you can get a compression test on each cylinder done so you determine if that is true or not. i'm still wondering who did you oil change, maybe they didnt put the right amount in
SimpleUser
Apr 24, 2021 02:54 AM
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
