nasty rattling from dash?
Old Mar 27, 2004
zen_master's Avatar
yo guys,
have some of u noticed rattling noises from the dashboard? is it common? is it fix-able?
i attached an image from ludlamtheory's post...
Old Mar 27, 2004
My car has so many rattles. The dash isn't easy to take apart, so you just have to live with them.
Old Mar 27, 2004
zen_master's Avatar
yay,
i think so...
just live with it...(hix hix hix)...oh well...
i think, it's only in winter...cos' probably it shrinks a lil' bit...and creates rattles
Old Mar 28, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I had the worse rattle coming from the same area once... oddly enough though, it was from a loose bolt in the engine compartment causing a washer to rattle on the body. Eh
Old Mar 28, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
I've got that rattle. My car's fix: Turn the heat on so that it comes out the dash vents for a minute or two. Once it heats up it goes away.
Old Mar 28, 2004
zen_master's Avatar
hm, very interesting..
yeah, ur right...if i turn on the heater for a while, the rattles gone....i think....hm..
wait2, screws in the engine compartment? can u tell me which one?
i actually do have a plan to tighten all the screws that loose...
Old Apr 1, 2004
meezo's Avatar
meezo is an unknown quantity at this point
mmmm its so ****ing i hate it when i travel 2 other countries .. took the care 2 dealel but with no good execuse as usual!! as they told me its coz u replaced ur sterio with amodified 1 the sounds has appeared so it will not be done on warrenty .. i gues they dont know what is really the problem !!
but after using my finger tacking every single part of dash i fount that the plastic case which is along to the front glass from the inside connected 2 the dash is the 1 tacking on the glass .. my temp soloution is tthat i incerted a piece of thick paper between the cover & the glass .. wala .. no more sound !!!!
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
ricer_em2
May 11, 2016 08:09 PM
cferry7
Oct 18, 2015 06:32 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
rovafa2002
Sep 28, 2015 06:57 PM
