Why does my car jerk?
Old Apr 17, 2004
BoSS's Avatar
BoSS is an unknown quantity at this point
Unhappy Why does my car jerk?
Can someone please tell me why my car jerks when I maintain RPM at 3500 in everygear?
It only happens when I maintain RPM.....When I'm gasing its normal.
It cant be the plugs, cuz I changed to OEM NGK TWICE..
It cant be the Coils, cuz I had them changed too..
Someone told me it could be the fuel injectors...
Can someone help me?
Pleeeeeeeeeeeeeeeeeeeassssssseeeeeeeeeeeeee?!
Old Apr 17, 2004
BoSS's Avatar
btw.....fuel economy is not effected....I still get the same milelage I did when the car was new...
my car is 120 000km
Old Apr 18, 2004
nivenmk1's Avatar
nivenmk1 is an unknown quantity at this point
I'd suspect the timing is off.
If you have a timing light and the shop manual (available from Honda) I'd check it just to be on the safe side.
If you've not done any head work, and the timing is in fact off, there are a couple of contingencies:
1.) Your ECU is shot.
2.) The crank-position sensors is shot or going bad.
3.) Some other position-type sensor is on the way out or dead.
In the case of #2 and #3, you could probably figure that out with an Ohm meter and the shop manual.
As a last resort, there is always Honda. Even better if you're still under warranty.
Old Apr 18, 2004
BoSS's Avatar
NoooooOoooOOOOOooooo.........
So it sounds like a serious problem then...
I hate my car.......
I dont have any head work......All I got is CAI, header, and a catback system.
I'm way off waranty so now my life just sucks...
Thanks for the help...
Any other analysts out there that might be able to tell me what may be the problem here?
All inputs will be helpful
Thanks
Old Apr 18, 2004
nivenmk1's Avatar
Chatted with my dad about it earlier when we were discussing cars, he was a mechanic for about 16 years...
He thinks it's your O2 sensor and clogged catalitic converter or a plugged fuel filter...
I'd say probably the first step is checking the fuel system... Try running a tank of FI cleaner, see if that helps.
Old Apr 18, 2004
armieo's Avatar
< My future wife.
That happened to my pontiac and my dad replaced his fuel pump. That's all I remember. I'm not saying it is the solution. So don't flame me guys.
Old Apr 19, 2004
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
If this is your first problem after 120K km, I'd say you're doing alright. I would have a diagnostic run on your ECU. The information that results should point you in the right direction, but O2 and crank sensors DO go bad.
usajags84
15
Aug 19, 2015 03:12 AM
ChristinaVHH
May 10, 2015 03:51 PM
JjAnGPeETuL
Nov 8, 2001 06:37 AM
CiViCPrAnInG2k1
Nov 2, 2001 02:49 PM
ImmortalEX
Oct 31, 2001 10:00 PM
