DIY: Hood rattle repair.
Ever since i got my car the hood would rattle. If I turned the rubber stoppers then it would stop but the hood stuck up too far. Heres what i did. The end result is no more rattle and the hood is flush with the fenders.
I took a length of black electrical tape and wound it around the catch latch located on the underside of the hood about 5 times. The result was a solid latching of the hood.
For future referance, the tape may eventually wear though and require replacement, other than that, good call.
If the tape does wear through, I'd get a roll of the clear-duct-tape and try it out, seems to be tougher than any other tape I've used under my hood...
That would be good 'n tough.
You could also go down to your local ACE hardware and look for some of that reinforced plastic tubing; has nylon string in it for better wear characteristics...
Also if you dribble some superglue in the slit and let it get good and glued it should never come off... I do the same thing to protect the A-arms on one of my RC cars (it does 0-62 in about 3.5 seconds) that sees a lot of offroad high speeds...
Niven = hobbiest
Niven = hobbiest
Re: DIY: Hood rattle repair.
GOD this has been driving me freakin crazy. just did the electrical tape fix and it worked like a charm. have any sugestions for an exhaust rattle that seems to be coming from nowhere? i've tried exhaust wrap everywhere i thought it could be rattling but havent fixed it yet. it only comes around 1700 to 2xxx rpms
damn. i bought the car with it so i didnt know that. that sounds like where its coming from though. do you think the cat could be going bad or something. it sound like a metallic fart. i can get it to fart on command by putting the car in 3rd at 25mph and giving it a little gas.
rnaodm
Sep 21, 2015 12:42 PM
