PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 [43] 44 45 46 47 48 49 50
  1. 2 Questions Pleez
  2. getting screwed, help!!!
  3. 2 questions...
  4. Is it just me or the car
  5. Click when pressing clutch
  6. 2001 DX with no A/C help!!!
  7. Car starts but guages dont work!!!!!
  8. Headlight Dillemma...I NEED your opinions asap!!
  9. Front Valance
  10. Car shakes when A/C on
  11. V-tech
  12. door panel removal
  13. A whistle inside my car
  14. Hey Need Help with BP Valve
  15. Rattle in dash
  16. sqeaking coming from belt in engine
  17. What should I do...
  18. body kit problem
  19. left front stabilizer link, how important?
  20. Please help! Problem with rear turn signal lights!!!
  21. Is it Normal for a closed sunroof to rattle a bit while driving?
  22. Rattle in door. Any suggestions?
  23. Electronics in Door?
  24. hard time taking off the silencer help help
  25. Maintanence question.........?
  26. Blown Motor
  27. Maintenance Required Light........???
  28. HX Problem
  29. damaged bumper support on 03 and dealer won't do anything
  30. HELP I cannot get my octane sides to fit
  31. Where the f**k are honda civics made.
  32. need help with rattles from my system
  33. Loud Ticking When I speed up and Slow down?
  34. Any1 have these problems
  35. alarm problem
  36. Aftermarket Shifter w/ Stock Boot
  37. my trip to the dealership
  38. 2003 civic rattle
  39. Driving cycles?
  40. Serious Problem Here!!!
  41. High Idle After dropping engine
  42. My civic gets dents too easy
  43. do i change oil filters, transmission fluids at 20k or still too early?
  44. SRS light
  45. aem cai broke!!
  46. do you change your own oil?
  47. battery dies and humming
  48. There's a dent on my dash :(
  49. Clicking when accelerating?
  50. Headlights problem!?
  51. Here we go... again...
  52. idle problem..
  53. anyone else have screwy doors locks
  54. 3rd brake light not working
  55. Terrible gas mileage
  56. How many miles until we should change our FUEL filters?
  57. 2001 LX won't idle
  58. .:Bumper Predicament:.
  59. Having a problem.
  60. Dents! Help!
  61. Booooiiiiing (spring noise)
  62. Signal Help!!!
  63. Car not starting, 3 times to dealer
  64. To the dealer...
  65. Fuel Gauge
  66. My marker light is running with signal light, help!
  67. Rear deck
  68. The Problem W/rear Suspension Squeaking
  69. SRS light problem from neons!?!?!
  70. Big Problem!
  71. 2k1 Suspension and Clutch
  72. HELP: Need to replace 3 wheel studs
  73. Burned Clutch
  74. Rear Suspension Squeaks?
  75. some type of exhaust problem
  76. 2 pipes on the back...
  77. check engine light
  78. when do u get your oil changed?
  79. this just came to my attention...
  80. Ploblem with AC and signal
  81. it's fixed!
  82. What should I do...???
  83. Fuse keeps blowing.
  84. S-afc problem
  85. I fixed trunk rattle!!
  86. bumper melting...help...
  87. How stupid is this...
  88. auto-locking in door doesn't work
  89. Horn/SRS/electrical?
  90. gx piston problems (removed them)
  91. Wimpy clutch
  92. Honda = Sheeit
  93. AC not cool at all
  94. Vibrating Sound with A/C
  95. Please help... screws stuck in air filter housing
  96. Cold air intake
  97. Door Dents, Dings, Scratches!??!?!?!?!?!?!!?
  98. Grease
  99. Maintenance requirement light
  100. 40k mile maintenance
  101. Which fuses?
  102. 20,000 Maintenance Schedule
  103. Maintenance @ Other Honda Dealerships?
  104. front vibration
  105. 30,000 miles major maintenance due soon
  106. side mirror fell off
  107. Question for anybody with injen race division intake?
  108. something is broken
  109. white powder stuff from steering wheel
  110. Check Engine Light(Searched)
  111. Chirp while rolling
  112. pulsing coming from clutch
  113. Fuel Problem Or Something
  114. Is this an alternator problem?
  115. Grinding in 3rd gear
  116. Check Engine Light?
  117. Puddle problems in stock sedan
  118. Resetting the Maint Req'd light...
  119. 3rd gear problems
  120. SRS Light
  121. Unbelievably tight screw
  122. hesitation on start up
  123. CV Boot and Honda Warranty Help!!
  124. 30,000
  125. 10,000 mile checkup
  126. Smoke from cat....
  127. Manifold Glowing?!?!
  128. trunk springs
  129. Has anyone heard of a "purge control valve"??
  130. Bottom strip of radiator coiling falling off
  131. Oil Pressure Sending Unit
  132. UPDATE:engine light came on my stock sedan. went to dealer & this is what they said
  133. My car won't redline!
  134. Clunk Clunk
  135. Clicking noise
  136. Radio Back light on
  137. Help! Wet Floors
  138. Hydrolocked or NOT!?!?
  139. help with getting front hub off
  140. What is wrong with my door????
  141. WW rear came off
  142. Leaking something from my bottom of my car
  143. Bad Sound When Braking
  144. gas milage and muffler....
  145. Auto. Door Lock Broken?
  146. clikcking sound when i turn right
  147. Oem Fog Light............
  148. Is the 20,000 mile checkup worth the money?
  149. POS plastic under engine bay
  150. remote problems?!?
  151. I'm having serious car trouble...
  152. Engine Light came on....and bypass valve
  153. air conditioner problem
  154. trunk rattle
  155. squeaking
  156. Sorta rough idle when first started in morning
  157. Noisy clutch return spring
  158. Reverse Noise *adivise?*
  159. Oxygen Sensor?!
  160. temp very high
  161. SRS Indicator...
  162. Main't Req Light
  163. Help. Engine light came on.
  164. Engince Ticking
  165. Touching up paint
  166. Warrenty stops Problems start
  167. exhaust options for a lx
  168. rear right corner suspension squeaking
  169. Auto Trany noise ?
  170. need sugestions
  171. shift boot
  172. Car Trouble
  173. Help Pulled Bumper
  174. Quick Help Please
  175. My rear is odd???
  176. This
  177. Clusters
  178. Trunk Ajar Light
  179. Backfiring?
  180. Twang
  181. Unsafe ride
  182. Manual Transmission Probs WHY???
  183. Water Leak Under Corner of the Dash on Drivers side
  184. Your answer may be here! TSB / Honda Complaint Address / Etc...
  185. HELP!! Exhaust burning bumper
  186. 60,000 Mile Tune-Up
  187. Problem with Radio, PwrDoorLocks, chime
  188. Mileage Concerns
  189. Gas Needle will Not Read Gas.
  190. right door panel rattle/vibrate with VIBE
  191. is it just me?
  192. gas MPGs jumped up!
  193. VTEC kicking iN?
  194. Weird Shaking
  195. Low Brake Fluid
  196. Weird rattling noise when I turn right...
  197. car takes a while to start
  198. Help Please
  199. maintenance required light?
  200. Check engine light drama!
  201. Rough Idle
  202. Engine redlines at 4000
  203. I HATE POTHOLES/HONDA SERVICE
  204. Hp Short Header
  205. Power Steering?
  206. HELP DEAD CAR!!
  207. ABS light
  208. Maintenance Req'd
  209. power steering fluid leaking !
  210. engine light at 2700K!!!!
  211. HELP!! ASAP!!
  212. wheelwell inner cover problem
  213. weather strip on my windshield
  214. cabin air filter ??????
  215. pwr locks
  216. rear axles sqeaks when hittin small bumps
  217. battery busted?
  218. Cracking noise from font of car
  219. Tyc projectors
  220. Great Gas Mileage all of a sudden? What happened?
  221. Engine "Pull" Seems Weird
  222. Any resolution to...
  223. Right Side Squeaking like Mad, Door and Etc
  224. exhaust rattle?
  225. HELP!! My Rear Night Light Doesn't Work
  226. 4x4 help!!!!!!!!!!!!!!!! ASAP!
  227. 2K1 Civic Oil Changes
  228. Blinker Not Working
  229. crunch in reverse (5-spd)
  230. Alternator died on me
  231. Warrenty law that Save's your a$$
  232. common probs to fix before end of warranty?
  233. malfunction indicator lamp
  234. Blown Shocks
  235. Warranty Work
  236. splash guard is rubbing a groove in my intake
  237. SRS Light
  238. Engine Light is ON - code (41)
  239. HELP PLEASE ASAP WITH TACH
  240. RPM range
  241. And the clearcoat cometh offeth
  242. My danged gas tank isn't 13.2 gallons
  243. Where does everyone find the service bulletins regarding our cars....
  244. just installed my intake and now my accelerates is slower
  245. Rattling in Passenger side door??
  246. SRS light...***i searched***
  247. Kangaroo ride
  248. Anyone tried racing their windows?
  249. car just caught on fire. wtf
  250. weird shaking in rain
