hard time taking off the silencer help help
Old Jul 19, 2003
03CivicEX03's Avatar
03CivicEX03 should not be trusted03CivicEX03 should not be trusted
i just installed my apexi n1 full-catback. friends and i were trying to take out the damn silencer off we try all most everything like screwdrivers, hax keys, etc. and still can't get it out the bolt is so hard and tight. Any idea need help help help.
Old Jul 19, 2003
Macfay's Avatar
Macfay is an unknown quantity at this point
spray some WD-40 and try losing it again
Old Jul 19, 2003
ptechricer's Avatar
ptechricer is an unknown quantity at this point
won that make a bad smell, do you usellay have to pull hard to get it off.
Old Jul 20, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
you can't get the bolt off? or you can't pull out the silencer?
if it's the bolt, wd-40 should be okay. If you're having a hard time gettin the actual silencer off, you can use peg board hooks from home depot.
the 2nd one from the left. buy 2 of those and use the hooked ends to tug on the silencer
from the inside
Old Jul 21, 2003
Master's Avatar
Banned by Admin
if it is the silencer, here is what you do. You get a pair of vice grips and clamp them onto the tube part of the silencer. The you get a hammer. There is a flat part on the vice grips that you can hit. So hit that and make sure you are going away from the muffler when you are hitting or you will hit it further into the muffler.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
crowtoo
May 11, 2015 06:50 PM
pheaton
May 4, 2015 08:26 PM
MamaBear2015
May 3, 2015 02:17 PM
GH04si
Apr 15, 2015 08:13 PM
