Rear Suspension Squeaks?
Old Jul 7, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Hey everyone, today I was removing my rear deck and when I was in the back seat taking everything apart, when I bounced up and down for no reason at all, my rear suspension started squeaking. I don't know if was both sides or just one, but either way I don't know if that is normal. Can you all please help me clear this up? Thanks!
Old Jul 7, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Does it happen when you're driving over bumps, or only when you're bouncing yourself up and down? If it's only during your bouncing, I wouldn't worry about it.
Old Jul 7, 2003
djaaronk's Avatar
djaaronk is an unknown quantity at this point
I get a squeak too...if you listen very closely when driving about 10mph...very slowly...you can hear it squeaking...sounds like an old rocking chair. Also when I do the bouncing thing it squeaks really bad. I did take it if for this and of coarse it didn't squeak when it was at Honda so they said nothing is wrong. Does anyone know what this is??? It isn't normal is it? BTW...my car is 100% stock.
Old Jul 7, 2003
ZSKCivic01's Avatar
Extreme Member
what djaaaronk said is exactly what I experience in my car. At low speeds my suspension squeaks like crazy, when I go up my driveway, and just bouncing up and down in the back seat. At high speeds though, you don't hear anything. Unfortunately I have new rims so my warranty on my suspension is void. Id really appreciate it if someone could tell me what this is caused by.
Old Jul 8, 2003
kalipnoi's Avatar
kalipnoi can only hope to improve
mine had the same problem. the dealership will say nothing is wrong but go to a respected auto shop and have them check out the bushings in the rear. that fixed my problem.
Old Jul 16, 2003
Fern's Avatar
The Greatest
Fern is an unknown quantity at this point
I had the same problem at low speeds, like pulling into or out of a parking lot incline, turns out it wasnt the suspension, but the rear deck had becoem loose somehow, they say its a common problem, especialyl after putting the rear seat down and having stuff on top of it while its down. They replaced and tightened the bolts and clips on the shelf and i never heard the noise again.
Old Jul 16, 2003
Nodnero's Avatar
My front creaks when I slow from first to neutral and goin over bumps as well. What is it?
juror
Suspension DIY
Jul 30, 2019 03:28 AM
EdGasket
40
Nov 27, 2015 11:11 AM
Strycker
Aug 2, 2015 08:40 PM
Misfit2613
Jul 30, 2015 09:49 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
