pulsing coming from clutch
I started noticing this about a week ago while I was on vacation. When I push the clutch in I feel a pulsing through the pedel. I have searced the forums and can't find anything. it get's really bad when I have the a/c on with recirculation on. And as always with Honda my warranty expired 800 miles ago comming back from my vacation. Can anyone let me know if you have this problem or if there is a TSB out there that could relate to this. Thanks
I have an ACT clutch and flywheel and have a pulse, it is directly related to rpm and gets worse at higher rpm, I can really feel it when I am barefoot. But since it is all aftermarket, I will just wait it out since warranty won't cover it anyways....
Yea I have the same problem..its more like a bunch of consecutive beats that you can feel and can actully hear when the clutch is pressed and more noticable when the AC is on. Ill prob bring it up on my next oil change but the problem is that its no a consistant thing...
Take off the pannel and shoot some greese on the clutch rod inside the car. it won't fix the problem but it will help it. It also gets rid of that clutch squeak that probably alot of you have experienced on the stock clutch.
dinsum
May 28, 2015 09:30 PM
crowtoo
May 11, 2015 06:50 PM
