ABS light
Old May 30, 2003
misio4's Avatar
misio4 is an unknown quantity at this point
Question ABS light
My car has 45,000 miles and couple weeks ago I changed the front brakes. Today on the way to work my ABS light came on. I didn't look under the hood to check the brake fluid yet. I don't know what could it be. The brakes work fine.
I think that either it is low brake fluid, or a sensor gone bad.
Any ideas??????
Old May 30, 2003
misio4's Avatar
I just would like to know what you guys would think the reason for the light coming on might be.
Old May 30, 2003
Chrisman8995's Avatar
Chrisman8995 is an unknown quantity at this point
1st check brake fluid, 2nd do yo still have good pedal (firm not spongy)
3rd if it doesn't snow or ice a lot where you live dont worry about it
Old Oct 29, 2003
mattskav's Avatar
mattskav is an unknown quantity at this point
Hey did you get an answer to this!
it just happened to me!
Old Oct 29, 2003
Voiceofid's Avatar
End Bringer
if you just had your brakes done, it could be that they fooled with the speed sensor while they were doing it, or they did something to the calipers
Old Oct 30, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
battery low might cost the abs light 2
Old Oct 30, 2003
mattskav's Avatar
no this is a random, electrical type problem.
if you shut the car off and turn it back on the abs will often work.
if you pull the fuse and pop it back in the abs will often work..
Old Nov 2, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
I have a similar issue. That'll happen to me, but once I move my car over a bump, it'll come back on.
Old Nov 3, 2003
gizcivic's Avatar
gizcivic is an unknown quantity at this point
i had this problem on my car i went to the dealer and just
reset it
Old Nov 3, 2003
mattskav's Avatar
What a freak little car! I took both of the front wheels off on Saturday and unpluged the abs sensors (Orange connectors just inside the wheel lip), plugged them back in, and the ABS light STAYS ON.
Later that day it went out and it's been out ever since...
Someone call the exorcist...
Old Nov 3, 2003
All Eyes On Z
... I'm gonna try that.
Old Nov 14, 2003
cdmx's Avatar
Any update on this? i was in an accident and my abs light is on. I need to know how to reset it. Breaks work fine.
Old Dec 22, 2003
mattskav's Avatar
my light came back on and is on, fkuck it....
Old Dec 23, 2003
cdmx's Avatar
how do you reset it?!!! is it ok to leave the battery connected and unhook the abs fuse and put it back in?
Old Dec 23, 2003
cdmx's Avatar
I cant take my civic back to honda cause ive changed alot of stuff i even mounted the fuse box in a different place...
Old Jan 3, 2004
HondaLuver's Avatar
Its a celebration bitches!
dam my light just came on, and the abs doesn't work, it just went on out of no where and it never has done that, i just hit like 50k
Old Jan 5, 2004
HondaLuver's Avatar
the only things i can think about causing this problem could be
1. Lose sensor somewhere
2. low brake fluid(well mine is low)
3. low abs fluid
4. malfuntioning abs unit
Old Jan 6, 2004
Zzyzx's Avatar
Autocross Junky
#1 rule on repairng cars is...... Replace the cheepest part first.
so, First i'd check the fuses, then check the fluid, then take it to the dealer ship because if it is the ABS unit, you wont beable to fix it at home.....
HondaLuver, there is no "ABS fluid", the whole brake system is tied together and then ABS unit is just a series of Valves and pumps that kick in when the computer tells them to...
question... when you turn on the car, does the ABS unit sound like its pumping? if it is then you may have gotten air in to the unit. and that would kick off the ABS light.
Old Jan 8, 2004
HondaLuver's Avatar
i checked the brake fluid, and all the abs fluid. i actually looked at the brake fluid amount and it wasn't low, haha it looked like it though, any ways, i tried to listen to the abs unit and it didn't make any sounds. i think it might be either the abs unit or there is a lose line some where, where i usually park there are spots of fluid on the floor and it looks like brake fluid.
its from the front of the car. so im going to take off my rims and check all the abs lines
Old Jan 9, 2004
Captain's Avatar
Captain is an unknown quantity at this point
Holy crap....this just happend to me this morning. All I did was stop on some snow. Didnt even do anything different like slam the brake or anything because there wasnt anything around me. I need to go out and check whats up with it.
Old Jan 12, 2004
HondaLuver's Avatar
i found out why i got a abs light, i just got some new rims and i checked all the abs sensors, and i found that the rear left brake sensor was off, so there was a missing bolt that held it in place. maby i was lose when i got disc brakes back there... humm, another one solved by me
Old Jan 13, 2004
Captain's Avatar
Mine just turned off on its own and has been off since it happend. Wierd....
Old Jan 15, 2004
yellowcoppy95's Avatar
yellowcoppy95 is an unknown quantity at this point
i dont know if this will help or not but when ever i am feeling a little crazy and want to pretend like i have a rear wheel drive car so i can go drifting/ powersliding in a dirt parking lot all i do is go really fast and turn the wheel eithe rright or left and then pull up the e-brake and the rest is the fun part. but after doing this the abs light came on for awhile but then turned itself off so i think that it might have been one of the sensors that had gotten dislodged slightly and then after the last powerslide it reset itself. hope this helps
Old Jan 16, 2004
HondaLuver's Avatar
no the reason that it comes on is because it senses ur tire being locked for a long period of time and messes with teh car...
conspiracy90
Jun 7, 2023 01:01 PM
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
