Is this an alternator problem?
Old Jun 24, 2003
Sivion's Avatar
Resident Tough Guy
Sivion is an unknown quantity at this point
Question Is this an alternator problem?
Hey guys,
Well after hearing a strange squeeling noise under my hood, I think I am hitting my alternator too hard. Can anyone recommend what high output alternator would be good for this setup?
(2) - 800 Watt Fosgate Amps (I think)
(2) - 10" JL Audio Subs
Underbody Neon Kit (StreetGlow Gold Series)
(2) sets of mini strobs (front and rear of car)
Colored fog lights in front
(5) Assorted Neons in car (2 - 5", 1 - 10", 2 - 9")
Reverse indiglo guage faces
(3) 2 1/4 AC mini guages (reverse indiglo)
**Anyway, I noticed that after awhile with all these additions, when I am sitting idle up to about 1.5k RPM's, there is this whining sound coming from under the hood. IF I turn my steering wheel it goes away. Or if I rev the engine or start moving (obviously producing more RPM's) From the searches I have done it sounds like the alternator can't take it. Anyone got a good replacement in mind for what I am running?
BTW even with everything on, and my stereo bumping as hard as it can, the lights will not even flicker a little. Also all my neons are on switches, so they are only on when I toggle them . Same with the strobes.
Old Jun 24, 2003
flotsamm's Avatar
Sounds like its related to your power steering pump or belt if the noise goes away when turning. A quick test is to disconnect your amps and listen to see it disappears. Also maybe think about installing a voltmeter.
Old Jun 24, 2003
solar's Avatar
solar is an unknown quantity at this point
A alternator under a heavy power load will make noise similair to a power steering pump. If you draw heavy amperage from the alternator the regualator is wide open and the internal field and windings are going as hard as possible.
If I were you I'd take my car to a good Starter/Alternator shop and have them to a amp draw test on your car. Basically you turn everything on in your car and the shop will detemind if you need a beefed up alternator. If you do nned to get a upgraded one, get ready to put out some serious $$$$$$. I've seen some peole spend upwards of $700 to $900.
Black91civic
Jun 6, 2015 08:15 AM
HiImBrandon
Jun 1, 2015 07:34 AM
jackoncruzpr
May 24, 2015 12:24 AM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
smmahan
Apr 15, 2015 08:17 PM
