Clusters
Old Jun 5, 2003
Phanibal's Avatar
Phanibal is an unknown quantity at this point
Question Clusters
Does anyone know if an SI cluster will fit inside of a DX? If so is it easy?
Old Jun 6, 2003
XtremeJM's Avatar
nope, different wiriing harnesses.... there may be a way, havent tried it, but if you get the wiring harness, you can just splice each wire where thye belong, all are color coded. Good luck
Old Jun 10, 2003
Phanibal's Avatar
Thanks alot xtremejm, but I don't think I want to mess with wiring stuff because I don't know **** about it, also lets say I do use a different cluster, then later switch back to my old one, would anyone every know that I changed the miles?
Old Jun 10, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Search this... it's been beaten to death
The cluster only stores the miles recorded while it is plugged in. The ECU actually keeps track of the miles on the car. If you remove the cluster, and it says 11000 miles, then 10 years from now if you go to trade the car and swap the original cluster back in, it will still say 11000, someone will check the computer and know the milage is not accurate. Best thing to do is get an LX cluster from a car that has more miles than you have now, when you get to the milage put in the new cluster. That way, you're still accurate and no one can raise a fuss. When you get rid of the car, you'll have to leave the swapped cluster in the car. But no matter what, the car loses value because you don't have the original odometer reading. Why not just get a small aftermarket tach and mount it someplace not very obvious (not a ricer 5" tach, they make 2-3" ones). I believe 'Bellz' mounted one in the bezel in front of the cluster in his car and it looks very good. Search for threads on Tachometers in DX models and you should find it.
Old Jun 10, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Thank you Boilermaker... they should make you mod of this section
-Locked-
fatih717171
Jul 25, 2016 06:22 PM
hondacivic0253
Sep 29, 2015 08:06 AM
260000milesgoal
Sep 25, 2015 07:41 PM
rayman009
Sep 12, 2015 08:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
