RPM range
Old May 21, 2003
Samari's Avatar
RPM range
I have a question about what RPM range we are suppose to be in at 80mph. When i drive home from school or just anywhere, when im at 80mph im at a constant 4000 rpm's. Is that normal. All my friends are at about 3000 rpm's. They dont have a civic like mine but they do have a honda. I have a 03 honda civic ex manual. Someone let me know whats up?
Old May 21, 2003
Weaponx12o's Avatar
cant really tell, it depends on how hard you're stepping on the pedal, what gear your in, if your going up/downhill or flat. i have an auto and at 80, im at around 3300-3400 rpm's (cruising though). there was a thread similar to this a while back. try searching for "rpm" or something like that, it might still be around
Old May 21, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Slightly different gearing between auto and manual, and VTEC and non-VTEC (or LX vs. EX).
4000 rpm at 80 mph cruising sounds about right for a manual EX, so don't worry about it. Civic VTEC engines rev higher than most other cars.
I'll check today on my way home what mine is, but I seem to remember it being around 3500 rpm at 70 mph, so it should be somewhere close to your range at 80 mph (EX manual too).
Old May 21, 2003
Vytas's Avatar
Vytas is an unknown quantity at this point
Ronin's right. Do not worry about it...
Old May 21, 2003
flotsamm's Avatar
3900-4000 rpms is what I get also when cruising 80mph. Its going to be different depending on tranny and trim level.
Old May 21, 2003
PESTLNC's Avatar
PESTLNC is an unknown quantity at this point
3100rpm @ 80mph in 5th in my HX. Yay fuel economy!
Old May 21, 2003
luckynumbernine's Avatar
luckynumbernine is an unknown quantity at this point
4000 at 80 is what i get. honda 4 cylinders are made to turn fast. that's where all the get up and go is. look at the powerband on a gs-r or even the s2000. don't sweat it one bit. i had the same concern when i first had my car as well.
Old May 22, 2003
Samari's Avatar
thanks for the help!
Old Jun 2, 2003
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
ex manual 5th gear
RPMS Speed
2000 40
3000 60
4000 80
5000 100
6000 120
7000 140
Old Jun 2, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
one more thing about that...won't we lose alot of gas driving constant 80 @ 4000 rmps? cause i get like less than 33mpg and i have 20k on my car (should be broken in already). And wuts with all those auto civics getting like 38's n stuff. >_<
Old Jun 2, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
If you compare someone driving at 55MPH while you drive 80MPH neck to neck, you will get less MPG than the person driving at 55MPH. Some people get 38+MPG because of terrain, driving style, cty/hwy, different octane, weather, mods, just to name few....can't really measure what is the correct MPG but 33 sounds about right for mixed cty/hwy
JetsterDajet
52
May 8, 2016 12:11 AM
Bikergofast
Mar 9, 2016 07:08 PM
mistahlorax13
21
Nov 18, 2015 12:47 PM
Juanb24
Sep 15, 2015 12:39 AM
Bricoleur
Sep 9, 2015 12:23 PM
