side mirror fell off
Old Jun 27, 2003
orion_squall's Avatar
ok,
finally, someone accidentally or on purpose hit my left side mirror and it fell off a bit.
it can still move, because I guess the power line are still fine except the mount is broken.
I read bunch of DIY but I am affraide of taking off door panel, because my left door panel is already rattling with loud music.
someone here in GREATER TORONTO AREA, HAMILTON or BURLINGTON is familier with door side panel removal and can fix the side mirror? I might "hire" one person like that...for 50$ C.D
Old Jun 27, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
You don't need to take off the door panel to fix your mirror. Just take off the triangle plastic (pry it off using a flat screw driver) and there should be 3 round screws holding your mirror.
For $50, you can get a new pair. Why would you paid someone to do it when you can easily swap the mirrors yourself...IMO.
Old Jun 27, 2003
I hear a lot that if you want to keep the triangle plastic in a nice state, you have to open the door panel, then remove it.
and one screw is hidden under the door panel.
that what I see in forums...can someone back "HappyGilmore" up. BEcause I also hope I won't need to remove the door panel!!!!
Old Jun 27, 2003
Mbow's Avatar
No, you don't have to remove the door panel in any way. Just pry the triagle piece up from the bottom so it pops free. I mean just so the bottom pops outward but the top is still flush.
Then, just lift the triagle piece towards the sky about an inch and pull it away from the door.
There should be 3 screws under there but I can't remember. Those 3 screws hold the mirror on.
Trust me, you don't need to remove the door panel for that little piece.
Old Jun 27, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Correct you don't need to remove the door panel to remove the triangle piece. This is exactly why I got the UK-spec folding sidemirrors. Our U.S. civics should have had this standard like the 5thgen civics and below.
Old Jun 27, 2003
thanks guys!
how about putting triangle piece back? it will be hard?
Old Jun 27, 2003
Mbow's Avatar
No, it's real easy. You'll see once you get it off.
Old Jun 30, 2003
ok, thanks,
but for M3 mirrors we must open door panels, because we want to pass the signal light wires through. right?
Old Jun 30, 2003
trashguy's Avatar
trashguy is an unknown quantity at this point
roger that
Old Jul 1, 2003
JoeyOKC's Avatar
http://ackakaka.ytmnd.com
JoeyOKC is on a distinguished road
it's a 2 minute job. I had to do it a couple weeks ago after I knocked the driverside mirror off. d'oh
Old Jul 2, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
take your time doing it you dont wanna drop the nuts into the door. then you'd really have to take the whole panel off if you do.
Erndog81
Oct 31, 2015 03:01 PM
671civicLX
Jul 9, 2015 03:22 PM
ballmich
Jul 9, 2015 11:59 AM
Dean Walker
Jul 7, 2015 02:27 PM
nongv
Jan 2, 2002 02:09 PM
