PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50
  1. ATTN: CARS WITH VIBRATION IN RAIN
  2. gas peddle vibration on 2K2 Civic LX
  3. Break Groan!!... NO one else has this problem?!?!?!?!
  4. My Muffler Doesn't Sound right HELP!!
  5. 5000 mile gas mileage report
  6. Anyone can help with my interior rattle, PLEASE!
  7. Popping out of 2nd gear..
  8. New Car Mileage?
  9. Low revolutions issue.......need advice.
  10. Talked to a Honda mechanic...
  11. Honda bulletin for rear deck rattling
  12. CHECK ENGINE LIGHT HELP!!!!
  13. Fuel economy at WOT and low RPM?
  14. tire steering suspension problems
  15. WTF!!! problems??????????
  16. Too much coolant?
  17. Making Wierd Noise from front wheel
  18. passenger tire clicking
  19. squeeking in the rears
  20. Bad tires?
  21. mileage question
  22. HELP!!!! WITH SECURITY?!!!!!
  23. Wheel hop!!!
  24. Wheels spin when in neutral and car off the ground.
  25. Speedometer Needle Problem...Anyone Else?
  26. INJEN SRI/ AIR FLOW SENSOR
  27. Door lock noise
  28. my cars falling apart
  29. anti freeeeezzzee
  30. Dang Bulb!
  31. attn:2 cute
  32. changing a little light ??? help plz
  33. ENGINE REVS UP AND DOWN BY ITSELF
  34. Front drivers side rattle when hitting bumps
  35. Removing Door Pannels
  36. Worried about your rev limit in Park?
  37. Robber Stoppers w/ new car?
  38. no problems!
  39. Are Light Bulbs Covered Under Warranty?
  40. Clues for Hard Start Mystery
  41. i have these probs, can you relate?
  42. any one elses shift boot to tight?
  43. Keyless Entry
  44. Broken motor mount/ coil packs not sealed also
  45. shifter problem fixed
  46. Where is the air filter in our cars?
  47. Alternative to suspension leaking and shifter
  48. the honda dealer is the sh*t
  49. Glove box or passenger side vent rattle
  50. Rear Bumper Paint Difference
  51. Strange Hum while accelerating
  52. This an electrical prob?
  53. Swapping new rims back with my old ones??
  54. Problems with trunk latch
  55. grinding noise
  56. stock intake ?
  57. Help with Front Vibration
  58. Faint Burning smell..
  59. Speedometer stop working....
  60. 6 beeps
  61. do you guys get static shock
  62. 2nd gear getting off
  63. Recommended Maintenance
  64. maintnence light at 10000
  65. Door rattle by hinge
  66. Whew...car stalled and almost got hit...
  67. Sticky something
  68. cold air when turning
  69. INJEN SRI QUESTION
  70. Synchro gear problems
  71. TELL WHAT YOU THINK ABOUT WHAT COLOR .....
  72. closing power windows slow/seize
  73. WHat is the difference between the EX and the 1.7i ES model?
  74. Crazy Auto Tranny
  75. shifting in auto
  76. OEM Motor Mounts
  77. AC Reverse indiglo problems...
  78. Piaa Xtreme White Bulbs.. How long are they suppose to last?
  79. dent in hood from hail, how to remove?...
  80. Rear suspension squeaking.
  81. how do i remove my dash?
  82. shifter problems
  83. Problem starting car !!
  84. Gauge Problems
  85. hittin rev limiter...
  86. DC headers question
  87. scratches on audio console
  88. Is my clutch going?
  89. do I need need to get certain tires for rims
  90. Key won't come out ignition revisited...
  91. books on fixing or my civic 2001 "mechanic books"
  92. Sensitive Steering
  93. preventing rust off care in the winter, practically impossible
  94. warranty issues
  95. Pain in the A$$ Dealership
  96. are these problems
  97. check your seatbelts
  98. HELP ME!!!!!!!!!!!
  99. HELP ! clutch problem turning to nightmare.
  100. Weak Braking
  101. Injen SRI burning hose??
  102. Deck lid not Latching
  103. has anyone's "check engine" light come on yet?
  104. PIAA Extreme Wedge Parking Lights Warranty
  105. A/C Problems & Surges
  106. Clutch?
  107. Dent on hood
  108. License plate rattle
  109. Many problems, any solutions?
  110. Annoying vibrations when idling. Please help!!!
  111. Parking Lot Dents
  112. Shocks seem kinda "crunchy" in cold weather.
  113. Wrecked my LX
  114. WTF? My car ALMOST did not start!
  115. passenger seat walk-in feature with memory
  116. Reverse Indiglo problems....
  117. Help!!!... Some Oil Stains on Floor..
  118. Any Probs with the 2k2 Civic?
  119. My dealer sucks, does yours?
  120. SIDE AIRBAG ISSUE/SUGGESTION
  121. door panel rattle on coupe
  122. Konis installed...
  123. Dealer fixed two of my problems
  124. check engine light
  125. Car Wont Start!?!?!?!? HELP!
  126. CAR WONT START !?!?!?!?! HELP!
  127. Has This Happened To anyone Else???
  128. Rear seat belts tension up and lock??? (sedan)
  129. Interior Lights just winked out!!
  130. BROKEN HEADLIGHT
  131. ABS Light is on
  132. at how many miles did/do you get new brake pads?
  133. wierd noise when revving
  134. Obstruction in Gear Shift
  135. I stalled my car twice!! just really worried
  136. Rear brake drum service bulletin
  137. 2k1 Civic Aircon Foul Odor
  138. rattle when AC is on
  139. My post is gone
  140. Bad Oxygen Sensor?
  141. Class action suit against American Honda???
  142. engine check light "emissions light"
  143. steering wheel emblem
  144. Dumb question
  145. Is there something wrong with my civic??
  146. 2k2 civic owners
  147. Is this Murphy's Law or what!
  148. Stinks!
  149. Have any of you ever called Honda Client Relations about your problems?
  150. whats the +'s and -'s of the new 1.7 liter?
  151. Rattle in driver's side pillar '01 Sedan
  152. Auto-Down Window stops
  153. car stalls is it because of aftermarket shiz?
  154. What to do if a dealer will not fix a problem with a car?
  155. Why so High?
  156. Downshift Adjustment
  157. Car moves in NEUTRAL???
  158. Cold air intake problem!
  159. White stuff in engine oil
  160. lug size??
  161. speed sensor...???
  162. tire prob's
  163. Wierd sound after letting go of gas...
  164. So many problems?
  165. mysterious rattle
  166. Moonroof Rattle
  167. exhaust touching bumper
  168. turn signals...
  169. Carpet Lumps...
  170. Major Stereo Prob (please help)
  171. seatbelt making sounds
  172. Rear Window Tint Removal...
  173. Rear bumper of Body kit
  174. WTF??? Speedometer "breaks" this morning...
  175. Link to site with TECHNICAL SERVICE BULLETIN numbers
  176. knocking suspension fixed under SERVICE BULLETIN
  177. 17" rims eats gas
  178. Stock cd player changing radio stations by itself
  179. are all ex's supposed to come with rims?
  180. Does anyone find the seat handle a bit clumsy?
  181. Update on grill mesh problem with Tsunami bumper, please help
  182. key wouldnt turn in the ignition
  183. Blown rear passenger shock...no suspension mods...under warrenty?
  184. tick,tick,tick
  185. was my spoiler installed wrong?...
  186. i hate my firestones!
  187. Wheel Hop, Loud Bang
  188. has anyone noticed a knocking noise coming from the wheels when turning?
  189. Sporadic Cracked Windshield
  190. HERE'S THE PICTURE OF THE CAR!!!!
  191. 2001 HONDA CIVIC BLOWN MOTOR
  192. What Wheels Will Fit On Our Car?
  193. GC coilovers popping
  194. intermittantly pulling to the right?
  195. any clues as to where this noise is coming from???
  196. vtec in 2k2 civic ex
  197. ok ok ok
  198. Is the 2000 civic better???
  199. BLINKERS TURN SIGNAL!!!!!!
  200. passenger side seat belt slider rattles bad
  201. Rattling noise from rear window
  202. My 02 Civic
  203. COLD START
  204. Petitioning HONDA, is there strength in numbers
  205. Anyone had their CD door pop off yet?
  206. Any problems with "notchy" shifters on '02s?
  207. Damn horns keep going off when i leave my car, anyone else?
  208. car shakes like a siv!
  209. procarparts.com SRI
  210. 205/40/17 becareful!!
  211. DIY rattle????
  212. Skunk2 installation
  213. RECALL: Belt Buckles
  214. Horn acting weird when the A/C is on or at high speeds?
  215. Exhaust Sound?
  216. imagine a dealer who refuses to fix a problem with a car.
  217. Waz up w/ my alarm
  218. bad strut
  219. oil and gas mileage
  220. Shifting from 1st to 2nd requiring more blending??
  221. noise like gurgle/compression
  222. Am I the only one?
  223. Extreme Wind noise
  224. driving problem
  225. NO HEAT ON MY FEET
  226. hey im new
  227. <Tape deck Backlight problems!> help plz!
  228. headlights...is it just me, or....??
  229. Driver's side front window SLOW
  230. Ice trick for dents
  231. Tpye R and Type S
  232. IDLING AT 6000RPM!!! HEEEEELLP **update**
  233. E-Brake Problem?
  234. A NEW problem with clearing headlights! Read! Solutions welcome!
  235. CAR TURNS OFF
  236. Vibration when idling.
  237. misaligned trunk lid?
  238. picking up car today,,,
  239. SRS airbag sensor problem - solved, ignore.
  240. 215\40\17????
  241. Intermitent Starting Problem
  242. Question on AUTO TRANNY! HELP!
  243. Problems? When you bought your car?
  244. Problems with Coupe or Sedan?
  245. rough seam inside stock headlights
  246. I'm tired of this
  247. Oh yea.....another strange thing...
  248. Gas gauge reading way off.....
  249. abs problem
  250. cheap way to fix plate rattling
