shifter problems
Old Mar 30, 2002
mpcivic2k2's Avatar
mpcivic2k2 is an unknown quantity at this point
shifter problems
had trouble putting car into 4th gear. it was real tight and it made a squeek as if rubber was rubbing and then it makes the same noise going into 5th but not tight. I took it back to the dealer and they checked it out and they said something is wrong with the bushings. I don't remember his exact explanation but whenever i get the problem fixed after the parts come in I'll post what actually happened, if i find out. At least the car is still driveable, it just sounds really crappy when I shift into 4th and 5th. Anyone else have this problem?
Old Mar 30, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
This is the first time I've heard of 4th and 5th gear problems on these cars. Most people with gear problems complain about 2nd gear.
Old Mar 30, 2002
Pyro's Avatar
Pyro is an unknown quantity at this point
I had this problem with 2nd gear (they won't fix "can't reproduced the problem") but never heard this for 4th & 5th
Old Apr 2, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
<< I had this problem with 2nd gear (they won't fix "can't reproduced the problem") but never heard this for 4th & 5th >>
theres a service bulletin, im sure you can find it somewhere on this site. take it back and make them look it up so they have to fix it. they are lying to you about no problem found because its a very well known problem, they just dont feel like fixing it
Old Apr 3, 2002
Pyro's Avatar
i know they know aobut the bulletin but if they can't make it happen there they won't fix it....it only happens like once every couple weeks or so...
TuRtLE714
Jan 5, 2002 09:14 PM
Jodster
Dec 29, 2001 09:00 PM
Poysynfree
Auto Transmission failures
Dec 13, 2001 06:08 AM
CiViCPrAnInG2k1
Dec 6, 2001 12:14 PM
01civicboi
Nov 23, 2001 03:02 PM
