License plate rattle
Old Mar 22, 2002
SpacemanBob's Avatar
SpacemanBob is an unknown quantity at this point
My license plate rattles whenever I close my trunk, and also sometimes cause of the bass. Anyone know of a fix? I'm pretty sure it's just the license plate hitting the trunk....
Old Mar 22, 2002
emmagatorone's Avatar
emmagatorone is an unknown quantity at this point
If you have a frame around the plate, lose it! If it's just the plate, take it off and bend it so it's not really touching the car at all, not too much but just enough so it won't touch. Another option that I don't know for sure works or not is going to the hardware store and getting those little rubber clear dots that have an adhesive on the flat side and sticking them on where the plate touches the car. Good luck.
Old Mar 22, 2002
CIVICTypeRookie's Avatar
CIVICTypeRookie is an unknown quantity at this point
Slap some Dynamat (you know what that is right???) on the back of your license plate will make those rattles go away for-ev-er!!!!
You can get it a most car audio shops. They sell it in big sheets so you'll have a lot left over which I suggest you line the
inside of your trunk lid with.
Old Mar 22, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
my license plate came with little rubber sticky things and i put them on and it doesnt rattle or scratch the paint anymore
Old Mar 23, 2002
HondaUSDM's Avatar
HondaUSDM is an unknown quantity at this point
yep, u can put strips of dynamat around the border of the plate. or go to home depot and get these foam strings, it comes in a long *** roll for about $1 and one side of it is adhesive and u can put that all over ur plate so it's not that metal on metal sound
Old Mar 23, 2002
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
i just stuck on dish washing sponge stuff.. but the rough side touching the plate... duh..
Old Mar 24, 2002
speedracersong's Avatar
<< i just stuck on dish washing sponge stuff.. but the rough side touching the plate... duh.. >>
[IMG]i/expressions/laugh2.gif[/IMG]
DUH!
anything that soft works. just put it behind the plate. prob solved
Old Mar 24, 2002
Mbow's Avatar
I had a problem with mine rattling once. I can't remember what it was from. Anyhow, I just took a hot-glue gun and glued the plate to the inside of the frame. Never rattled again.
rovafa2002
Sep 28, 2015 06:57 PM
