PDA
View Full Version : Mechanical Problems/Vehicle Issues and Fix-it Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50
  1. Anyone a real tech here?
  2. Wierd noise coming from the brakes
  3. glare on front window from dash
  4. Brake light flashes on and off
  5. Irritating RATTLE!
  6. can you hear the gas swoosh around in your gas tank?
  7. roof trim unglued from TOP
  8. P1519 Idle Air Control Valve Circuit Failure
  9. Another problem!
  10. gargling sounds
  11. Faint 3000 rpm Rattling Sound
  12. Cruise Control On/Off Button Light burnt out
  13. Help me please!
  14. Is my clutch not disengaging?
  15. Drum Brakes water noise?
  16. Need suggestion on misfire in startup
  17. Car running like crap
  18. Woah...rust?
  19. HELP Headlight Problems, Low beams wont work wtf!
  20. HELP - Problem with Car CD player
  21. transmission noise please help
  22. Honda 2003 Civic LX
  23. my friends maxima has a problem
  24. Man I'm frustated at my Vic
  25. Removing coins stuck behind the coin box
  26. fluctuating idle
  27. Yup, All Read and help me out :(
  28. Clean rear box dust
  29. Coin box?
  30. Door not staying open
  31. Racing seats/SRS light....a different problem than the usual
  32. help with my headlights
  33. Car sometimes wont start!!!
  34. Cleared headlights having blowout issue?
  35. Right Rear Strut Creak and another Pop?
  36. Warranty Question
  37. I need you input on my headlight...please help??
  38. DC racing headers
  39. Hot exhaust clicking noise
  40. Piping Hangs Low & Frame Pos. bend, Why? Pics Included
  41. Help Dealership Is Raping Me!!!!!!!!!
  42. Just install Exhaust.. problem ...
  43. Strange vibration noise at 2500 RPMs???
  44. intake broke under my hood
  45. rolls backwards in drive
  46. Rust and salt problem
  47. Rear right wheel noise???
  48. which fuse goes to the cigerette lighter?
  49. feel the road in steering wheel ?
  50. Speedometer bounce
  51. Trany popping out of gear
  52. How to empty gas tank?
  53. Ac Smells Like Rotten Eggs???
  54. How to adjust a slipped steering wheel???
  55. Problem!! Engine Check Light...
  56. valve-clearance
  57. 2001 civic valve tick
  58. Axle help!
  59. Hit a deer.
  60. Any other 2001 with the fix-A/C,Brake Light &P/L Problem
  61. Aint this a *****
  62. clutch grinding
  63. Air leaking through vents when off
  64. Gas Problem
  65. Driver Side Wiggle...
  66. Replacing broken mirror...
  67. Sunroof Smashed
  68. rattling or grinding
  69. New spark plugs and WORSE gas mileage...
  70. 5th Gear Slipping??
  71. rattle clip pop chirp,
  72. pass. door panel rattle ?
  73. Magnaflow Installed!!!!
  74. coolant issues (update on post 6)
  75. SparkPlug Wires question?? :)
  76. High pitched noise? help plz
  77. ABS comes on at low speeds?
  78. WTF IS GOING ON!!!HELP (engine)
  79. Trunk Light won't turn on!
  80. Are Honda Batteries Better?
  81. Brake Noise
  82. why does this keep happening?
  83. Bootleg fuel sending unit / gas gauge...
  84. Noise From Rear End
  85. new radiator...
  86. Blinker
  87. need help rattling noise
  88. transmition clicking?
  89. Spark Plugs: Iridium, Platinum or Copper?
  90. Questions on when to change/service tranny & a/c system:
  91. some strange problems this morning
  92. dashlight issue!
  93. 2003 Civic Sedan - Hesitation (Posted Previously in wrong forum)
  94. Do you do a full stop before putting car in reverse?
  95. Replace the TCC Solenoid?
  96. dont know what title to make for this...
  97. 2005 Civic LX air conditioner woes
  98. how to remove air filter?
  99. removing 05 civic factory stereo
  100. oil leaking out of valve cover
  101. hood vibration
  102. rattling noise in front after parking
  103. 96CivicVtechE My Cooling fan wont turn on
  104. three codes on 2001 civic ex
  105. Steering Shakes.. VTEC Q...
  106. drivers side headlight flickering..dont know what to do??
  107. P1106 code what to do? pls.
  108. Headlight bulb
  109. Does Any One What This Could be ?
  110. exhaust rattle
  111. RPM is dropping while driving
  112. Weird Squeak...
  113. Car Wont Start
  114. so now i have a wiring problem
  115. Stock 01 rear suspension Sqeeek..HELP
  116. JDM DC5 Steering Wheel Causing SRS Light
  117. front light out
  118. Starting to hate my dealer
  119. Dash lights do not come on.. car won't start..HELP!
  120. Odd Problem: Engine Turns Off When Breaks Applied with Check Oil and Battery Light On
  121. How to adjust idle rpm ?
  122. Growling noise from back of engine
  123. Shaking/Miss-firing?
  124. Pedal Vibrations
  125. 02 Susp and Man Trans Problems
  126. Dash trunk light on but the trunk is closed?
  127. pulley help
  128. 94 Honda Civic EX misfire?
  129. Popping sound when shifting
  130. i turned the steering wheel, but nothing happened...
  131. Brake fluid Ex.
  132. Shift knob
  133. skirt corner comes up
  134. clicking when starting to move
  135. auto trany
  136. Two quick questions
  137. Need Help P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
  138. How long is Battery Life?
  139. dont start
  140. P0113 ??'s
  141. Which PCV and where does it go???
  142. cars burning oil
  143. headlight wire connector
  144. A/C Question/Problem
  145. battery light is flickering
  146. where isthe ecu located?
  147. VTEC Question
  148. Anyone have to replace any of the dash lights yet?
  149. 98 hx non vtec OBDII p1336?'s
  150. Blown fuse?
  151. How low should your gas pedal go down?
  152. Lowered Car - Now Cat Drags - Any suggestions?
  153. Fender Problems
  154. 2003 EX CP - P0420 Catalyst System Efficiency Below Threshold (Bank 1)????????
  155. Headlight Problems... HELP Please
  156. help w/finding ground wire
  157. cant get accurate reading on dipstick
  158. Stock clutch
  159. How to eliminate the rim or tire as the cause of my car pulling?
  160. Grill Not Working Wiht Body Kit
  161. What does this code mean?
  162. OBD II code- P0730 Problem in Shift Control System
  163. Weird noise coming from engine need help!!!
  164. OBDII Code P1166 (air/fuel metering)
  165. another problem: stock cd player
  166. problem with signal light
  167. altenator bolt
  168. no clutch pedal
  169. crazy problems
  170. Vibration at 1100 rpm
  171. Balancing Alloy Rims ??
  172. Excessive cranking at start up
  173. Burnt smell
  174. interesting idle problem
  175. Tranny slipping?
  176. throw out bearing
  177. Broken Wheel Bolt and Manifold stud
  178. Check engine question
  179. Electrical Problem (Caused by shop)
  180. Knocking noise! Plz plz help!
  181. Simple light Problem, But still can't figure it out..
  182. Steering Pop Noise
  183. Check Engine Light, OBD II code P1706
  184. nothing happens when i push the panic button...
  185. Clutch Pedal getting Hard
  186. Lost Keys
  187. Coolant splatter when filling reservoir
  188. PROBLEM: Rear LEDs blink too fast! HELP!
  189. Creaking sound after stopping the car
  190. Sensor in intake popped out, can't secure it
  191. I F'ed Up Big Time. i think??
  192. Engine Mount Issues
  193. OBD II Code P0132 - O2 Sensor
  194. Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
  195. Check Engine Light on, bring to dealer under warranty?
  196. Check engine light?
  197. Window Weatherstrip
  198. Slighty Bent Radiator
  199. ****Back plate touching rotor = Stranging clicking noise when turning right
  200. my car sucks in the rain
  201. What's the best way to get a dealership to work with you ?
  202. grrr... right headlamp fogging up...
  203. HID problems
  204. clutch
  205. Week of hell
  206. Flickering battery light on dash
  207. hood wont close
  208. tranny is slipping.. what to do?!?
  209. RPM goes up and down
  210. a tricky problem
  211. starting trouble
  212. 95 Civic EX 1.6L - AC issues
  213. clicking on the shifter??
  214. Transmission Whine - Normal in 4sp Auto
  215. Problem with Door panel - 05 coupe
  216. transmission bearings
  217. Gas needle doesnt know where to go?
  218. lights don't turn on and check engine light is on
  219. tranny dead where can i go?
  220. My civic is loud, in a bad way...
  221. Warrenty
  222. 0420 engine code
  223. FORUM RE-ALIGNMENT. confused? read here
  224. alternator low output
  225. transmission grinding
  226. Transmision Noise
  227. first civic problem yay!!! :(
  228. Power Window Switch broken
  229. airbag light on
  230. Weird Radio Problem
  231. what's wrong with my speedometer?
  232. Temp. gauge oscillating...WTF?!?!
  233. Interior Shifter light out?
  234. Post timing belt question
  235. Headlights keep blowing bulbs (lowbeams)
  236. Flyer fell down the driver's side window.
  237. Radiator Fan!!
  238. Crank pulley bent?!?!?!
  239. 2001 Honda Civic LX Air Conditioning Issue?
  240. My gas door won't open, It broke!
  241. Need major help, Car does Not start after Fuel filter change????
  242. A/C Problem
  243. A/C air conditioning warm
  244. HELP, still no pressure, all new parts!
  245. ECU Problems?
  246. Here you can find the diagrams of any Honda
  247. Annoying high pitched sound coming from the front driver's side of the car...
  248. Break-in = Water leak!!!
  249. Weird noise coming from my AC.
  250. Brake help
