98 hx non vtec OBDII p1336?'s
Old Aug 25, 2005
nfrost's Avatar
nfrost is an unknown quantity at this point
New here .
200K on 1998 hx civic coupe non vtec. CEL with code p1336. The decoder thread says RPM flucuation sensor signal interupt.
Question's Where is this sensor in on the engine? Where can I get a FSM hardcopy on this ride? and how do I reset the CEL (the fuse block in the engine bay is not numbered) so I'm not sure of the location of #6 as stated in the CEL reset thread.
TIA
Cheers
Nathan
Old Aug 26, 2005
streetglower's Avatar
that code doesnt neccessarily mean the sensor is bad. it could be bad, or you could have a wiring or ECU issue. You have to do the procedure outlined in the manaul to diagnosis it. Now I dont know if the codes are the same for the 98 as the 01-03, but I would help you but ony have the 01-04 civic service manaul.
But autozone should have a copy of the hanes service manaul for like $20 and that should explain the procedures for checking the code in there.
Old Aug 26, 2005
nfrost's Avatar
Thanks for the reply, I plan on getting a manual this weekend. Have a feeling that it might be a short in wiring. Mice in the enginge bay at times
Elciteeve
Sep 28, 2015 12:40 PM
Dave Brabant
Sep 27, 2015 09:43 PM
beanhead
Sep 24, 2015 12:04 PM
chiquita.banana
Sep 24, 2015 09:42 AM
Dave Brabant
Sep 12, 2015 08:39 PM
