Magnaflow Installed!!!!
Old Sep 11, 2005
DowntownRicer's Avatar
DowntownRicer is an unknown quantity at this point
edit: See Question on #7....
Just finished my install. Boy did it take foerever. Its not a hard install, but the bolts were so old and rusted that you needed to be the hulk to get them things off. The main thing that took forever was that the stock resonator and muffler were rusted together so tight I was thinking about cutting the pipe until it finally came apart very greasely I might add. (extra 20min) Then right when things were looking good the freakin right bolt from the piping to the stock header broke off. At that moment Im like ooooo . So after a trip to the auto store were we picked up some bolt extraction bits it was back to work. Then it took like 30min to drill the thing because we had a bad angle and werent working with much clearance. Eventually the screw broke off (3 drill bits later that is) and we drilled straight through the mounting bracket which didnt take too much damage in the attempt. It got an extra mm or so on a small portion of it but thats about it. (1.5hrs added) So we mounted everything up, im going to head to honda to get some more screws for were the header and piping connect because mine arent worth keeping, unless someone can suggest another place. After all of that, 5hrs later, the thing is on, it sounds pretty good, smoked a hell of a lot, only problem now is that the factory springs surronding the screws are so warped that they rattle like crazy(not as tight as they used to be) when you rev up and it makes this weird sound like the engine is burping. I drove it down the road seems to sound good.
So does anyone have any advice for me after all of that ... much feedback would be appreciated.
Btw: Is the engine (around the header) suppose to smoke as well as the exhaust, cuz mine did a lil, the exhaust did a lot.
Old Sep 11, 2005
04hemiboy's Avatar
04hemiboy is just really nice04hemiboy is just really nice04hemiboy is just really nice04hemiboy is just really nice
I believe the smoke your seeing is from inside the new exhaust from when they mandrel bend it they use oil.
Old Sep 11, 2005
slicksivik's Avatar
weld the midpipe
Old Sep 12, 2005
when u say the mid pipe, do you mean both connecting points or just the very center one.
Old Sep 12, 2005
blouisgod's Avatar
Life Begins > 6800rpms
i just every joint welded - 20 bucks at the muffler shop.
Old Sep 12, 2005
Another question, was i supposed to remove the adaptor piece that sits between the stock piping and the header assembly. I did if you wanted to know, but the thing wouldnt fit with it on, it fits snug and exactly without it.
Old Sep 12, 2005
LX Exhaust install QUESTION....HELP PLEASE
Okay I got my exhaust installed and im so paranoid I think somethings going to snap off when im just driving. Someone said I should weld the midpipe, so I've already looked into that and whenever I get some time im going to do that. The only other question that is killing me to know the answer too is if removing the circular adaptor piece on that helped mount the stock exhaust was correct. In the DIY's and even the instructions it doesnt mention this piece, but when I removed the factory exhaust the header had a circular adaptor piece on the mounting point. Trying to place the MAG's mounting pipe over it proved to be impossible, at least from my perspective. So the question is, was it right to remove it? When I removed it, it fitted just fine and screwed down with no problem. So please someone answer me, did I do it right when I removed that piece? (I can get you a pic if you need it)...and i did search, but i found no mention of this piece.
Old Sep 13, 2005
streetglower's Avatar
I merged your 2 threads together since you already had one started on this issue, so please refer to this thread.
Old Sep 13, 2005
CMON someone has to know the answer to this......
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
