Dash lights do not come on.. car won't start..HELP!
Old Sep 1, 2005
o2civic's Avatar
o2civic is an unknown quantity at this point
I had a problem today..
I went to put in gas and fill the tank to the top. When I proceeded to start the car the car didn't start... It will crank, but will not start. I noticed that the lights on the dash do not come on.. you know how all your lights come on (engine, srs, key immobilizer, oil... ect..)when you set your key on ACC? Well, NO light came on. I can hear that beep but no lights.. All other lights on the car work fine.. Radio fine, headlights.. everything fine.
At first I thought it could be the gas.. but then why would my dash lights not come on? I figured Ignition problem.. I even pondered the fact that it could be the key immobilizer that comes from stock.. After playing around with the ACC. IGN, CRANK, brakes and auto shifter.. The lights all came back and I was able to start the car. The lights came on before, but I still wasn't able to start the car.. This time it started.
Any ideas or suggestions?
I have a Clifford Intelligard 850 alarm.. But it has never given me issues.. I've had it for well over a year.
Old Sep 2, 2005
jttegx's Avatar
OMNES AD UNUM
is dimmed? the small **** that you turn... if so, turn it clockwise.
could it possibility be a battery thats close to dead?
Old Sep 2, 2005
o2civic's Avatar
No. It's not the dimmer. I could swear it has something to do with the key immobilizer.. its like its not recognizing the key or something..
Old Sep 2, 2005
sometimes that happens as the key ages. or if you have it next to another imm. key when starting.
Old Sep 7, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
or fuses could be blown on the car. if you pull all the fuses from the alarm you should be able to start the car.
CarStuff
Dec 6, 2020 12:52 PM
twtron
Apr 17, 2015 12:09 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
NukeSilo
Nov 4, 2001 09:37 PM
