Lighting Wireing
Old Nov 4, 2001
NukeSilo's Avatar
NukeSilo is an unknown quantity at this point
Hey Im gona have lots of neon lights running in my car and each of them wired to switchs that have 3 positions off,headights,on. Where would be a good connection to connect to for the headlights, so when i have my parking lights, or headlights on, the neons would be on. i really dont want to run a cable all the way under my hood to my headlight, is there a solid closer connection. [IMG]i/expressions/face-icon-small-confused.gif[/IMG] Thanx
Old Nov 4, 2001
Jochij's Avatar
Jochij is an unknown quantity at this point
Hey i can't help u with the wiring but i think its illegal to drive in florida with neon lights. And if u have them attached to ur headlights wires then the police will make u cut ur wire.
Old Nov 4, 2001
VNlilMAN's Avatar
The Standard One
thats why he has a switch to turn off just the neons. and cops usually won't pull you over just for your lights.
well anyways, i have an automatic so i used the connection thats lights up the 'P''N''D'... this lights up when you turn on the parking lights(as well as headlights) tho. if you have a manual, just look for anything that lights up when you turn on the headlights and connect it there.
Old Nov 4, 2001
Perfectcivic's Avatar
Perfectcivic is an unknown quantity at this point
Pull out the 2 panels under your steering column and look for a bunch of wires goin through the firewall pretty well up in there. youll know which one cuz you can see it from your engine bay goin to your lights. find a red and black wire and tap into it thats what i did for my indiglos and indiglo pedals. If you need any more help check out the wiring diagram on the site and be prepared to have a sore *** neck
Old Nov 4, 2001
NukeSilo's Avatar
Ok thats cool thanx [IMG]i/expressions/face-icon-small-smile.gif[/IMG] but im gona have alot of stuff going off that wire, can it handle all that or is there a better place to do it at.
Old Nov 4, 2001
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
if your gonna have alot of lights running off of the wire use a relay....just use the wire from the lights as a signal to turn on the relay....it's quite simple...Relays are an installers friend
Blazz
May 25, 2015 10:56 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
blackbullet
Dec 1, 2001 03:44 PM
AzNmiKex215
Nov 29, 2001 08:02 PM
NukeSilo
Nov 20, 2001 05:17 PM
