Engine Mount Issues
Old Aug 15, 2005
uselessclown's Avatar
uselessclown is an unknown quantity at this point
Engine Mount Issues
my engine mount is torn, i was wondering does this happen often, it looks pretty flimsy and i was wondering if anyone has had similiar problems, i went and got another one from the dealer but it doesnt look like it will last to long IMO.
Old Aug 15, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
it's pretty common to break/tear engine mounts ... happens on ep3s and rsxs as well
Old Aug 15, 2005
Jrfish007's Avatar
You could upgrade. I think Hasport makes some for the stock civic.
Old Aug 16, 2005
ive seen kits on ebay but i was wondering do they make engine mounts for automatic can one for a manual transmission fit on a automatic?
Old Aug 16, 2005
Jrfish007's Avatar
I think it depends on which mount you are replacing. The best thing to do would to call Hasport, they are the specialist in this and will tell you everything you need to know. Personally, I would stay away from the ebay ones, unless they have a good brand name to them, they are probably worse than OEM.
Old Aug 18, 2005
fixeruper's Avatar
fixeruper is an unknown quantity at this point
good info, just tore mine two days ago, the pleasure of turbos, lol
Old Aug 20, 2005
has anyone seen the engine mount inserts, i was wondering if a engine mount for a manual trans, and a automatic trans are shaped diffrently where the inserts would go
Old Aug 21, 2005
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
If you get inserts, buy a new stock mount anyway and put them in that.
Old Aug 22, 2005
2K1Civic17"Gabe's Avatar
I have ripped my front mount, and my tranny mount. Its normal. I now have polyurethane inserts, and they work awesome. The cars sort of shaky, but not bad. Keeps the wheels planted much nicer, too. No wheel hop at 10psi in first, lol.
No more turbo on my car either, haha.
Old Aug 22, 2005
The Energy Suspension Motor Mount Inserts will work with auto or manual. I have manual, but the tranny mount doesnt get touched. They give 2 mounts for the front, and 2 for the rear. Youll only be able to fit one in the rear, if you go through the trouble of grinding it down. A dremel works nicely. There is way too much width for both to fit in, AND get bolted back onto the mount frame thing on the car
Its worth it to get them all in though, IMO. I have 3 in, and they make a tremendous difference, lots of vibration though, but I like it and so do girls, hehe.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
mikemc422
Aug 9, 2018 05:41 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
streetglower123
Apr 12, 2015 10:56 AM
