my friends maxima has a problem
She gotta 1997 nissan maxima. she says that sometimes it takes about 3 or 4 tries to turn on her car. she also said that when it turns on and its just idling for about couple minutes the car will shut off on her by itself. anybody know whats the deal is? she changed her altinator not too long ago but its still having problems.
Thanks.
Thanks.
if you not gonna post something that could help me and my friend out, dont bother posting. i know damm well this isnt a maxima site. doesnt hurt you or anybody else to ask a simple question.
Wiggle the shifter (if auto), the contacts are probably dirty/corroded and its not sensing the car is in park. My Mom had a 93 Max, same problem and its intermittent. I'm sure you could alcohol the contacts off and get it to work better, but shaking it a little did the trick. The guys on maxima.org may know the exact root of the issue.
Drunken Master-7thgen Ninja
Thanks.
Thanks.
1. spark plugs
2. spark plug wires
3. ignition coil
4. bad fuel filter
5. VACUUM HOSES- i think its this one from what you described about the car shuttin off on its own.
6. bad alternator/battery
7. clogged fuel lines/ injectors
if i can think of anything else, ill tell ya. good luck
bad fuel pump, or bad fuel pump valve
try turning the car to the run postion (where the radio and windows and all that work, but the car isn't actually running, but all the lights in the dash are on). Let the car set like this for about 5-10 seconds, then try and turn it on. If this works, the return valve in the fuel pump is broken.
Other than that, I think everything has been mentioned
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Touge
Ottawa
May 23, 2015 05:39 AM
tylerginevan
Apr 27, 2015 12:29 PM
